[Mapserver-users] perl-mapscript compilation error... did I miss
something in the archives?
Gerry Creager N5JXS
gerry.creager at tamu.edu
Sun Mar 2 20:03:00 EST 2003
Yes... I never saw it do anything resembling a 'clean' but *I* did... In
reviewing it, 3.7 cvs appears to not have mapscript_wrap.c anywhere.
And when I stuff the 3.6.4 version in, it neither compiles clean, nor
does so even with a 'c++' substitution as recommended in the Wiki.
Cluelessly yours,
Gerry
Lowell Filak wrote:
> Is it possible the cvs version (3.7) that you downloaded has a broken makefile that is doing 'clean' before doing 'all'?
> Lowell F.
> The following message was sent by Gerry Creager N5JXS <gerry.creager at tamu.edu> on Sun, 02 Mar 2003 01:49:29 -0600.
>>MS 3.7, Linux RH8.0, Kernel 2.4.18-24, perl 5.8. I do a 'perl
>>Makefile.PL' followed by a 'make' and here's what I get...
>>[root at vne-dhcp-047 perl]# make
>>Running Mkbootstrap for mapscript ()
>>chmod 644 mapscript.bs
>>rm -f blib/arch/auto/mapscript/mapscript.so
>>LD_RUN_PATH="/root/mapserver-3.7:/usr/local/lib:/usr/lib:/lib" gcc
>>-shared -L/usr/local/lib mapscript_wrap.o -o
>>blib/arch/auto/mapscript/mapscript.so -L/root/mapserver-3.7 -lmap -lgd
>>-L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz -lpdf -ljpeg
>>-lfreetype -lpng -lz -lproj -ljpeg -L/usr/local/lib -lgdal.1.1 -lming
>>-L/usr/local/lib -lcurl -lz -lssl -lcrypto -ldl -lz -lpthread -lm
>>gcc: mapscript_wrap.o: No such file or directory
>>make: *** [blib/arch/auto/mapscript/mapscript.so] Error 1
>>Where did I step off the cliff?
>>TIA, gerry
>>Gerry Creager -- gerry.creager at tamu.edu
>>Network Engineering -- AATLT, Texas A&M University
>>Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
>>Page: 979.228.0173
>>Office: 903A Eller Bldg, TAMU, College Station, TX 77843
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Page: 979.228.0173
