[Mapserver-users] Installing Map Server on Mac OS X
Paul Ramsey pramsey at refractions.net
Mon Mar 3 11:41:12 EST 2003
Have you installed proj4? Your compile is dying at a missing proj4 function.
Paul
M-Rick wrote:
> Hi have tried to compile it following the instruction on this page :
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MacOS
> I have first, installed PostgreSQL and MySQL, GD, and libtiff. But the
> problem comes when I try to compile gdal 1.1.7
> i have done the manipulation in the gdalmake.opt
> but I get these errors when I do the make command :
> ogrct.cpp:420: `DEG_TO_RAD' undeclared (first use this function)
> ogrct.cpp:468: `RAD_TO_DEG' undeclared (first use this function)
> ogrct.cpp: At top level:
> ogrct.cpp:99: warning: `int projPJ(int, char**)' used but never defined
> ogrct.cpp:101: warning: `int projUV' defined but not used
> make[1]: *** [ogrct.o] Error 1
> make: *** [ogr-target] Error 2
> [Ordinateur-de-Aymeric-GILLAIZEAU:~/Desktop/gdal-1.1.7]
> I can give the ./configure log file and the make log file if needed.
> I'm using Mac OS X 10.2.4 + GCC 3.1 + Apple X11 + Freetype 6.3.3
> I don't know ho to build the proj.
> Thank you for your help.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
