[Mapserver-users] featurequery question
Lowell Filak lfilak at medinaco.org
Mon Mar 3 13:34:40 EST 2003
AFAIK a tolerance of 0 in the layer->queryByPoint should work fine.
Are you saying that if the tolerance is set to 1 it works?
Lowell F.
The following message was sent by "Debbie Pagurek" <pagurekd at agr.gc.ca> on Mon, 03 Mar 2003 11:14:21 -0500.
> I am experimenting with FEATUREQUERY - my qlayer is ecodistricts and my slayer is Ecozones.
> I am getting a list of ecodistricts as expected, however some of the ecodistricts fall outside of the selected ecozone.  I have tried setting the tolerance on both layers to 0, but if I do that I get a msQueryByPoint(): Search returned no results. No matching record(s) found error.  How do I make sure that the only ecodistricts found are the ones inside the ecozone and not adjacent to it?
> Thanks for any pointers anyone can send my way.
> D. Pagurek
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
