[Mapserver-users] shapefile programming
Hankley, Chip Chip.Hankley at GASAI.Com
Mon Mar 3 14:55:55 EST 2003
> As I understand, mapscript only works on NT if you use php.
> However, I'm wondering if I use a DOS window and invoke perl,
> will the mapscript.pm module then work?
> ...Kieran
You could pretty easily re-write the function in PHP. The syntax for
commands between PHP and Perl MapScript, and the code structure between the
two languages is very similar.
Chip
