[Mapserver-users] shapefile programming
Lowell Filak
lfilak at medinaco.org
Mon Mar 3 15:16:32 EST 2003
There lies a question ("I'm wondering if I use a DOS window") you could answer/solve for the rest of us.
Lowell F.
The following message was sent by "Kieran J. Ames" <kames at keyspanenergy.com> on Mon, 03 Mar 2003 14:17:13 -0500.
> As I understand, mapscript only works on NT if you use php.
> However, I'm wondering if I use a DOS window and invoke perl, will the mapscript.pm module then work?
> ...Kieran
> Lowell Filak wrote:
> > Sounds like a good case for an example so the perl mapscript program to do just that is at:
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex15
> > HTH
> > Lowell F.
> > The following message was sent by John Hagstrand <john.hagstrand at interageresearch.com> on Sun, 02 Mar 2003 13:01:21 -0600.
> > > Hi,
> > > I need a program or programmer to manipulate a Shapefile.
> > > I want to pull the bounding box out of the SHP file and put it in the DBF
> > > file.
> > > You see what I mean? I want to add four columns to the DBF file: north,
> > > south, east and west. And I want to populate those four fields to indicate
> > > the boundary of each object.
> > > Do you know of a utility program that will do this? If not, do you know a
> > > programmer who will write me such a utility program for a fee?
> > > Thanks
> > > John
> > > John Hagstrand
> > > Interage Research, Inc.
> > > 847 838 5371
> > > Software Development Consulting for Internet Content Management
> > > We make knowledge accessible, useful, and relevant for everyone.
> > > http://www.interageresearch.com
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
