[Mapserver-users] MapScript, help starting? (continued)
Dana Quinn
dana at nextbus.com
Mon Mar 3 15:44:30 EST 2003
Sorry if I'm coming to this late, I don't know what problems you've
had previously, but not having PNG and JPEG support when you use
Perl Mapscript sounds like some sort of build issue, does your
perl mapscript build link against all the proper libs to get
PNG and JPEG support?
Are you running this on some sort of unix?
dana
Junkmail Box wrote:
> I'm still having no luck getting mapscript to draw anything. My script is
> simply this:
> #!/usr/bin/perl -w
> use strict;
> use mapscript;
> $ENV{MS_ERRORFILE} = "/usr/local/mapserv/htdocs/arcata/foo.log";
> my $map = new mapObj('/usr/local/mapserv/htdocs/arcata/arcata.map') or
> die('Unable to open mapfile.');
> my $img = $map->draw() or die('Unable to draw map');
> my $void = $img->saveImage('/usr/local/mapserv/htdocs/arcata/example.png',
> $mapscript::MS_PNG, $map->{transparent}, $map->{interlace}, 0);
> The error log is reporting this:
> Mon Mar 3 11:49:44 2003 - msSearchDiskTree(): Unable to access file.
> Mon Mar 3 11:49:44 2003 - msSaveImage(): General error message. PNG
> output is not available.
> The first message, I gather from the mailing list archive, is a missing
> spatial index file and isn't terribly important. The second message seems
> to be the nasty one. If I change it to example.jpg and
> $mapscript::MS_JPEG, I get "JPEG output is not available"
> Any ideas what could be causing JPEG output to not work? The strange thing
> is that the mapserv CGI program works perfectly with PNG and JPEG output
> using the arcata.map file.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dana Quinn, dana at nextbus.com
NextBus Information Systems
(510) 420-3117
