[Mapserver-users] documentation bug (was Re: projecting a point
in PHP MapScript)
Chris Black
cblack at CalAcademy.Org
Tue Mar 4 17:35:15 EST 2003
--------------090702040709000501040409
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Ok, I'll download the 3.7 binaries and see if that helps. Thanks for
the info.
-- Chris
Daniel Morissette wrote:
>Chris Black wrote:
>>Eric Bridger wrote:
>>>Chris,
>>>1) pointObj->project() does not return a point, it just reprojects the
>>>pointObj, so getting a null is not an error.
>>In that case, the online PHP class documentation should be modified.
>> The doc at
>>http://mapserver.gis.umn.edu/doc36/phpmapscript-class-guide.html#proj
>>has this code snippet:
>Actually the 3.6 version "tries to" return a point but it's broken, it
>returns a point with an invalid internal poinObj reference, and the
>initial object is updated internally but the PHP wrapper is not, if you
>continue to play with the returned object you'll eventually end up with
>a crash. In 3.7 it won't return a point any more, instead it updates
>the point on which the project() method is called.
>I think your problem is simply that the project() method is broken in
>3.6 and cannot be relied upon. I'll see if I could backport the 3.7
>changes to 3.6, I just hoped that we could avoid that since very few
>people seemed to use those methods. The other option would be for you
>to use 3.7 in which the project() method works very well.
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title></title>
</head>
<body>
Ok, I'll download the 3.7 binaries and see if that helps. Thanks for the
info.<br>
<br>
-- Chris<br>
<br>
Daniel Morissette wrote:<br>
<blockquote type="cite" cite="mid3E6526D6.1EF85B21 at dmsolutions.ca">
<pre wrap="">Chris Black wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Eric Bridger wrote:
</pre>
<pre wrap="">Chris,
</pre>
</blockquote>
<pre wrap="">In that case, the online PHP class documentation should be modified.
The doc at
<a class="moz-txt-link-freetext" href="http://mapserver.gis.umn.edu/doc36/phpmapscript-class-guide.html#proj">http://mapserver.gis.umn.edu/doc36/phpmapscript-class-guide.html#proj</a>
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090702040709000501040409--
