[Mapserver-users] RE: querying from 3 tables
ryanne cruz ryanne.cruz at up.edu.ph
Thu Mar 6 01:31:10 EST 2003
hi list.
i have a table that has a column (named "households") with the number of
households in a certain area. this table (which i'll call table1) also has an
"area_id" column. every "households" entry has a corresponding "area_id" entry
but it is not unique. meaning a certain "area_id" can have more than one
"households" entry.
table2 also has an "area_id" entry which has a corresponding
"municipality_id". in table2 "area_id" is unique but not "municipality_id".
meaning a certain "municipality_id" may have more than one "area_id" partnered
to it.
in table3, the "municipality_id" is the primary key which means every entry of
"municipality_id" is unique in table3. every "municipality_id" in table3 has a
corresponding entry in the geom column.
i have a map of a certain province. i want to show the number of households in
each particular area of the province but i don't have the shapefiles yet of
those areas. but i do have the shapefiles of the municipalities in that
province. i want to add a layer on top of the province that will show the
distribution of the number of households in the province using the geom of the
municipalities. how do i do this?
thanks!
ryanne
