[Mapserver-users] Querying an Oracle Spatial with MS
Roberto_Santinelli
Roberto.Santinelli at pg.infn.it
Thu Mar 6 03:56:32 EST 2003
Hi everybody,
once discovered the possiblity to retrieve data from a Database, i just
tried to query my DBMS Oracle Spatial in the hope to display a shape layer i
know to be correctly populating the column GEOM of the table Particelle2 as
SDO_GEOMETRY object...
The syntax i used is resumed in the following lines (by the way i believe it's
all right)
LAYER
NAME particelle2
TYPE polygon
STATUS default
MAXSCALE 1000000
CONNECTIONTYPE oraclespatial
CONNECTION 'scott/tiger at escora.sitweb.it' #this is the DB
DATA "GEOM from PARTICELLE2"
CLASS
NAME 'county'
COLOR 220 224 230
OUTLINECOLOR 0 0 0
END
END #layer
But i have back as answer from MapServer (version 3.7 under W2K) the following:
"msOracleSpatialLayerOpen(): OracleSpatial error. OracleSpatial is not
supported "
Certainly the problem is in the unsupported OracleSpatial component.
But i'm not sure if the problem reside in the version used of MapServer dues
to the fact the it tried to use the msOracleSpatialLayerOpen() method.
It sounds like something elsewere is wrong,
but i don't know what....
Some hints or suggestions?
Thanks in advance for every kind of help,
Roberto
