[Mapserver-users] Graticule support not working?
Administrator jnovak at novacell.com
Fri Mar 7 01:22:42 EST 2003
I was hoping someone would use this code, but this is not what I hoped
WRT results...
The GRID was moved from inside FEATURE to the LAYER level, as you've
discovered.  I have not tested again on Win32 since the merge, so I need
to come up to date and retest.  I'll post with results when I complete
testing.
This sounds like an uninitialized variable in the GRID generation.  Sis
you just specify GRID, END in the map file, or try other parameters ?
Do you have PROJ compiled in and what environment are you running, Linux
John Novak
Novacell Technologies
www.novacell.com
-----Original Message-----
Sent: Thursday, March 06, 2003 5:46 PM
To: Brent Fraser; Daniel Morissette
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Graticule support not working?
Brent -
Well, if you put it at the FEATURE level now, you get an error, and if
you pull it up one level (inside the LAYER block), that seems to be
where the code expects it but it causes MapServer to hang.
	- Ed
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, March 06, 2003 6:46 PM
To: Ed McNierney; Daniel Morissette
Subject: Re: [Mapserver-users] Graticule support not working?
Hmm.  I've got code from around Feb 12 -17 ish that works ok, produces a
grid.  The GRID structure is at the FEATURE level.
Brent Fraser
----- Original Message -----
To: "Daniel Morissette" <morissette at dmsolutions.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, March 06, 2003 1:24 PM
> Daniel -
> I found the same code, and moved the GRID block up to the layer level.
Now MapServer hangs....
> - Ed
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Thursday, March 06, 2003 3:22 PM
> To: Ed McNierney
> Ed McNierney wrote:
> > I decided to play around with the new graticule code, and I can't
get it
to work.  I get a loadfeature (): Unknown identifier error for the
"GRID" line below:
> I get the same error as you on Linux with the latest 3.7 source from
CVS
> when using your layer defn.  Note that I have not played with the grid
> stuff yet so I can only confirm that I get the same error as you but I
> can't help.
> Well, maybe I can... ;)  Looking at mapfile.c, the loadFeature()
> function doesn't expect a GRID element, it seems that the GRID/END
block
> should be at the layer level.
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
