[Mapserver-users] sending image with mod_perl (conclusion)
Jason Thaxter thaxter at gomoos.org
Fri Mar 7 12:18:52 EST 2003
--QTprm0S8XgL7H0Dt
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
A quick re-summary of the issue: under mod_perl, stdout does not go to the
browser/client, it goes to wherever Apache thinks stdout is for itself.  So
	$img->saveImage(undef,
doesn't really work, though it may sometimes accidentally work, depending on
buffering issues.
So the solution is:
	1) extend mapserver code to add a "writeImage" function that takes a
	filehandle instead of a file name.
	2) extend the Perl interface through SWIG so perl can give the map object
	a filehandle to write the image on
	3) in perl code, get a filehandle to the browser/client and pass it to the
	writeImage function.
Attached you will find a patch against 3.6.4 for parts 1 and 2, and a very
minimal example in perl of how to accomplish part 3.  Maybe the execution
could be better, and GD-like behavior (e.g. "print $img->png"), would be more
elegant for the user, but this works now.
Hope this helps.  I'll copy this to the dev list later...
Cheers,
Jason
Jason Thaxter
GoMOOS, P.O. Box 4919, Portland, ME 04112-4919
Office Location: 1 Canal Plaza, 7th Floor
Office: 207.773.0423
Fax:    207.773.8672
Email:  thaxter at gomoos.org
------------www.gomoos.org--------------------
--QTprm0S8XgL7H0Dt
Content-Disposition: attachment; filename="mod_perl_example.cgi"
#!/usr/bin/perl
use strict;
# Map Server
use mapscript;
use XBase;
my $map = new mapscript::mapObj('/home/moxie/tmp/test.map');
my $img = $map->draw();
my $ref_img = $map->drawReferenceMap();
use Time::HiRes 'time';
my $start = time;
# these are for getting the filehandle
use Apache();
use IO::Handle;
my $fh; # this is the filehandle we'll pass to writeImage
if ($ENV{MOD_PERL}){
	$fh = IO::Handle->new_from_fd(Apache->request->connection->fileno(1),'w');
else {
	$fh = \*STDOUT;
use CGI ':cgi';
print $fh header(  # note the use of the filehandle here...
	-type => 'image/png',
$ref_img->writeImage($fh, $mapscript::MS_PNG, $map->{transparent}, $map->{interlace},0);
$img->free();
$ref_img->free();
--QTprm0S8XgL7H0Dt
Content-Disposition: attachment; filename="mod_perl_fixes.diff"
Index: map.h
RCS file: /data2/cvsroot/mapserver/map.h,v
retrieving revision 1.150.2.12
diff -b -u -r1.150.2.12 map.h
--- map.h	8 Jan 2003 19:06:59 -0000	1.150.2.12
+++ map.h	7 Mar 2003 16:53:28 -0000
@@ -729,6 +729,7 @@
 // Function prototypes, wrapable
 int msSaveImage(gdImagePtr img, char *filename, int type, int transparent, int interlace, int quality);
+int msWriteImage(gdImagePtr img, FILE *stream, int type, int transparent, int interlace, int quality);
 void msFreeImage(gdImagePtr img);
 // Function prototypes, not wrapable
Index: maputil.c
RCS file: /data2/cvsroot/mapserver/maputil.c,v
retrieving revision 1.108
diff -b -u -r1.108 maputil.c
--- maputil.c	9 Apr 2002 04:55:13 -0000	1.108
+++ maputil.c	7 Mar 2003 16:53:29 -0000
@@ -1183,6 +1183,59 @@
   return(MS_SUCCESS);
+** Write an image to a file handle
+int msWriteImage(gdImagePtr img, FILE *stream , int type, int transparent, int interlace, int quality)
+  if(interlace)
+    gdImageInterlace(img, 1);
+  if(transparent)
+    gdImageColorTransparent(img, 0);
+  switch(type) {
+  case(MS_GIF):
+#ifdef USE_GD_GIF
+    gdImageGif(img, stream);
+#else
+    msSetError(MS_MISCERR, "GIF output is not available.", "msWriteImage()");
+    return(MS_FAILURE);
+#endif
+    break;
+  case(MS_PNG):
+#ifdef USE_GD_PNG
+    gdImagePng(img, stream);
+#else
+    msSetError(MS_MISCERR, "PNG output is not available.", "msWriteImage()");
+#endif
+    break;
+  case(MS_JPEG):
+#ifdef USE_GD_JPEG
+    gdImageJpeg(img, stream, quality);
+#else
+     msSetError(MS_MISCERR, "JPEG output is not available.", "msWriteImage()");
+#endif
+     break;
+  case(MS_WBMP):
+#ifdef USE_GD_WBMP
+    gdImageWBMP(img, 1, stream);
+#else
+    msSetError(MS_MISCERR, "WBMP output is not available.", "msWriteImage()");
+#endif
+    break;
+  default:
+    msSetError(MS_MISCERR, "Unknown output image type.", "msWriteImage()");
+  return(MS_SUCCESS);
   gdImageDestroy(img);
Index: mapscript/mapscript.i
RCS file: /data2/cvsroot/mapserver/mapscript/mapscript.i,v
retrieving revision 1.66.2.1
diff -b -u -r1.66.2.1 mapscript.i
--- mapscript/mapscript.i	8 Jul 2002 17:28:16 -0000	1.66.2.1
+++ mapscript/mapscript.i	7 Mar 2003 16:53:30 -0000
@@ -989,6 +989,15 @@
     msSaveImage(self->bytes, filename, type, transparent, interlace, quality);
+  /* Make FILE * work */
+  %typemap(perl5,in) FILE * {
+    /* $target = IoIFP(sv_2io($source)); older swig */
+    $1 = IoIFP(sv_2io($input));
+  void writeImage(FILE *stream, int type, int transparent, int interlace, int quality) {
+    msWriteImage(self->bytes, stream, type, transparent, interlace, quality);
--QTprm0S8XgL7H0Dt--
