[Mapserver-users] query
Srinivas Reddy csr at rboxtech.com
Fri Mar 7 22:10:30 EST 2003
Thanks Mr.Eric. I applied as u said. still i am not getting.
i defined in this way my MAP file layer
 LAYER//Layer Def. start
    NAME "Boundary"
    STATUS ON
    CONNECTIONTYPE OGR
    CONNECTION "data/Boundary.tab"
    TYPE POLYGON
    CLASSITEM "NAME"
    LABELITEM "NAME"
    TEMPLATE "Malaya.html"  //I defined here the template
    METADATA
      "DESCRIPTION"   "Daerah"
      "RESULT_FIELDS" "Name"
      "WMS_TITLE"    "Selected Information"
      "WMS_ABSTRACT"    "more information."
      "WMS_SRS"    "EPSG:26915"
    END
    CLASS
     COLOR 255 255 200
     OUTLINECOLOR 0 0 0
     LABEL
          MINFEATURESIZE 40
          MINDISTANCE 150
          POSITION CC
          SIZE TINY
          COLOR  0 0 200
    END
    END
End//Layer Def. end
for the above layer i written this code for geting the result
if ( isset($map_x) && isset($map_y) && strcmp($zoomdir, "QUERY_POINT") ==
0 )
 echo "your at the query entery point just enter<br>";
 for ($ilayer=0; $ilayer<=$map->numlayers; $ilayer++)
   $selLayer = $map->GetLayer($ilayer);
  // Pointing the map point to where the user clicked
   $mappointq = ms_newpointObj();
  $mappointq->setXY($map_x,$map_y);
   echo $map_x. "<br>" . $map_y;
   //$selLayer->{template} = "bogus.html";
   $mappointq->setXY($map->width / 2,$map->height / 2);
   $queryResult = $selLayer->queryByPoint($mappointq, MS_MULTIPLE, -1);
   // here i am geting this error message " PHP Warning:  MapServer Error in
msQueryByPoint(): No matching record(s) found"
 echo $queryResult;
----- Original Message -----
To: "Srinivas Reddy" <csr at rboxtech.com>
Cc: "Mapserver List" <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, March 06, 2003 4:58 PM
Subject: Re: [Mapserver-users] query
> You misunderstood my point.  Your map file MUST define a TEMPLATE, even
> if the template is not used to display the results. queryByPoint() just
> quits if the layer has no template defined. Adding TEMPLATE "bogus.html"
> to your layer doesn't mean you have to use it.  Alternatively you can
> add to your code below:
> $selLayer->{template} = "junk.html";
> On Thu, 2003-03-06 at 04:34, Srinivas Reddy wrote:
> > Thanks Eric,
> > But i like to display the query resutls in the same page. I
> > written like this
> > for the above code i did not get any results. So how can i get the
results
> > form the layer? Can anyone help this point.
> > From: "Eric Bridger" <eric at gomoos.org>
> > To: <csr at rboxtech.com>
> > Sent: Wednesday, March 05, 2003 4:54 PM
> > You will need to define a TEMPLATE "template.html" in your LAYERS.  Even
> > if you do not want to use the templates.html to display the results, you
> > still need to have a TEMPLATE in the layer.  The html does not even to
> > exist.
> > Hope this helps.
> > Eric
> > On Wed, 2003-03-05 at 12:45, Srinivas Challa wrote:
> > > Hi Daniel,
> > > Thanks for the replay, I need ,”When I am clicking on map selected at
> > point or in rectangle area content recognitions with PHP.  I had written
the
> > map file like this
> > > MAP
> > >   NAME "New Demo"
> > >   STATUS ON
> > >   EXTENT 184861.560567497 88197.0005976087 2380774.92575433
> > 826403.167230631
> > >   SIZE 800 480
> > >   SHAPEPATH "data"
> > >   IMAGECOLOR 255 255 255
> > >   UNITS meters
> > >   WEB
> > >     IMAGEPATH "/apache/htdocs/tmp/"
> > >     IMAGEURL "/tmp/"
> > >   METADATA
> > >       "WMS_TITLE"     "New Demo"
> > >       "WMS_ABSTRACT"  "Information system"
> > >       "WMS_ACCESSCONSTRAINTS"    "none"
> > >       "WMS_ONLINERESOURCE"    "http://localhost:81/demo/demo.phtml"
> > >     END
> > >   END
> > >   # Start of reference map
> > >   REFERENCE
> > >     STATUS ON
> > >     IMAGE "graphics/refreance2.gif"
> > >     SIZE 200 80
> > >     COLOR -1 -1 -1
> > >     OUTLINECOLOR 0 0 255
> > >     MARKERSIZE 3
> > 826403.167230631
> > >   END
> > >   QUERYMAP
> > >     STATUS ON
> > >     SIZE 400 400
> > >     STYLE HILITE
> > >     COLOR 255 0 0
> > >   END
> > >   # Start of legend
> > >   LEGEND
> > >     KEYSIZE 18 12
> > >     LABEL
> > >       TYPE BITMAP
> > >       SIZE MEDIUM
> > >       COLOR 0 0 89
> > >     END
> > >     STATUS ON
> > >   END
> > >   # Start of scalebar
> > >   SCALEBAR
> > >     STATUS TRUE
> > >     COLOR 0 0 0
> > >     OUTLINECOLOR 0 0 0
> > >     UNITS kilometers
> > >     INTERVALS 5
> > >     SIZE  200 5
> > >     STYLE 0
> > >     LABEL
> > >       SIZE tiny
> > >       COLOR 0 0 0
> > >     END
> > >   END
> > >   # Start of symbol definitions (we're only using a few)
> > >   SYMBOL
> > >     NAME "circle"
> > >     TYPE ELLIPSE
> > >     FILLED TRUE
> > >     POINTS
> > >        1 1
> > >     END
> > >   END
> > >   # Start of layer definitions
> > >   LAYER
> > >     NAME "Boundary"
> > >     STATUS ON
> > >     CONNECTIONTYPE OGR
> > >     TYPE POLYGON
> > >     CLASSITEM "NAME"
> > >     LABELITEM "NAME"
> > >     METADATA
> > >     END
> > >     CLASS
> > >      COLOR 255 255 200
> > >      OUTLINECOLOR 0 0 0
> > >      LABEL
> > >           MINFEATURESIZE 40
> > >           MINDISTANCE 150
> > >           POSITION CC
> > >           SIZE TINY
> > >           COLOR  0 0 200
> > >     END
> > >     END
> > > End
> > >  LAYER
> > >     NAME "Fed_Rd"
> > >     STATUS ON
> > >     CONNECTIONTYPE OGR
> > >     CONNECTION "data/Fed_Rd.TAB"
> > >     TYPE LINE
> > >     #STYLEITEM "AUTO"
> > >     CLASSITEM "NAME"
> > >     LABELITEM "Name"
> > >     METADATA
> > >     END
> > >     CLASS
> > >      COLOR 255 0 0
> > >      #OUTLINECOLOR 255 0 0
> > >     LABEL
> > >           #MINFEATURESIZE 40
> > >           #MINDISTANCE 150
> > >           POSITION CC
> > >           SIZE tiny
> > >           COLOR  10 100 100
> > >   #SHADOWCOLOR  80 80 80
> > >   #SHADOWSIZE 1 1
> > >     END
> > >     END
> > >   END
> > >  LAYER
> > >     NAME "Highway"
> > >     STATUS ON
> > >     CONNECTIONTYPE OGR
> > >     CONNECTION "data/Highway.TAB"
> > >     TYPE LINE
> > >    # STYLEITEM "AUTO"
> > >     CLASSITEM "NAME"
> > >     LABELITEM "NAME"
> > >     METADATA
> > >     END
> > >     CLASS
> > > #SYMBOL "MYSYMBOL"
> > > COLOR  46 210 200
> > >     LABEL
> > >           MINFEATURESIZE 40
> > >           MINDISTANCE 150
> > >           POSITION CC
> > >           SIZE TINY
> > >           COLOR  0 800 200
> > >     END
> > >     END
> > >   END
> > >  LAYER
> > >     NAME "Railways"
> > >     STATUS ON
> > >     CONNECTIONTYPE OGR
> > >     CONNECTION "data/Railway.TAB"
> > >     TYPE LINE
> > >  STYLEITEM "AUTO"
> > >         CLASSITEM "NAME"
> > >  LABELITEM "NAME"
> > >     METADATA
> > >     END
> > >     CLASS
> > >   NAME "Rail Lines"
> > >   COLOR 0 0 0
> > >   OVERLAYSYMBOL dashed2
> > >   OVERLAYCOLOR 0 0 0
> > >   OVERLAYSIZE 3
> > > LABEL
> > >   MINFEATURESIZE 40
> > >   MINDISTANCE 150
> > >   POSITION CC
> > >   SIZE TINY
> > >   COLOR 100 0 200
> > > END
> > >     END
> > >   END
> > >  LAYER
> > >     NAME "State_Rd"
> > >     STATUS ON
> > >     CONNECTIONTYPE OGR
> > >     CONNECTION "data/State_Rd.TAB"
> > >     TYPE LINE
> > >     #STYLEITEM "AUTO"
> > >     CLASSITEM "NAME"
> > >     LABELITEM "NAME"
> > >     METADATA
> > >     END
> > >     CLASS
> > > COLOR 180 180 180
> > >     LABEL
> > >           MINFEATURESIZE 40
> > >           MINDISTANCE 150
> > >           POSITION CC
> > >           SIZE TINY
> > >           COLOR  220 100 0
> > >     END
> > >     END
> > >   END
> > >     # Seven Layer Under tesing Process...  sucessed
> > >  LAYER
> > >     NAME "Towns"
> > >     STATUS ON
> > >     CONNECTIONTYPE OGR
> > >     CONNECTION "data/ Towns.TAB"
> > >     TYPE POINT
> > >     CLASSITEM "TOWN"
> > >     LABELITEM "Town"
> > >    METADATA
> > >       "DESCRIPTION"   " Towns"
> > >       "RESULT_FIELDS" "Town"
> > >     END
> > >     CLASS
> > >         SYMBOL 'symbols/town.gif'
> > >       LABEL
> > >           MINFEATURESIZE 100
> > >           MINDISTANCE 450
> > >           POSITION LC
> > >           SIZE TINY
> > >           COLOR 40 100 40
> > >       END
> > >     END
> > >   END
> > > # End of the map
> > > END
> > > For the above map Script is working fine. But while I am querying  I
did
> > not getting the results. How can query the map using PHP at point and
> > selected rectangle area.
> > > Is any one can send the script for this.
> > > In this project i am not using applets. Just Map querying on 7 layers
> > using php.
> > > srinivasa reddy Challa
> > > > Now am new to this technologies but I had done some of project with
> > > > the reference of DM solutions map reference. In DM
> > > > solutions they are done using SHP data files. But  I am using
"*.Tab"
> > > > data. How can I query the content of the "*.TAB"layers
> > > > using php and mapscript.  This is my problem. This is my email id :
> > > > csr at rboxtech.com or reddy_challa at yahoo.com
> > > You will have to provide more details on what you are trying to do
> > > exactly if you want anyone to be able to help.
> > > If by "query the contents of .tab layers" you mean clicking on a map
> > > image and selecting features from a TAB layer then this works the same
> > > way for shapefiles and for .tab files.  The only difference is that
you
> > > need MapServer with OGR support, and you define an OGR CONNECTION in
> > > your LAYER.  For more details on using OGR CONNECTIONS, see the OGR
> > > HOWTO at http://mapserver.gis.umn.edu/doc36/ogr-howto.html
> > > Daniel
> > >  Daniel Morissette               morissette at dmsolutions.ca
> > >  DM Solutions Group              http://www.dmsolutions.ca/
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
