[Mapserver-users] projection problem
Stepan Kafka
stepan.kafka at centrum.cz
Mon Mar 10 04:26:52 EST 2003
You have specified targed projection the same (lat/lon WGS 84) as the source
data, so data aren't projected. Try UTM or Gauss-Kruger projection instead.
Stepan Kafka
Help Service Remote Sensing
tel: +420-327514118
mailto:kafka at email.cz
http://www.bnhelp.cz
> -----Pùvodní zpráva-----
> Od: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]za uivatele
> frauke.trurnit at gmx.de
> Odesláno: 10. bøezna 2003 9:24
> Komu: mapserver-users at lists.gis.umn.edu
> Pøedmìt: [Mapserver-users] projection problem
> Hi list,
> I have some problems with the projection. It seems as it doesn't work. My
> map looks like not projected.
> Does anyone have an idea what's wrong? I attached an example map
> of Germany.
> Thanks for help
> Frauke
> Mapfile:
> MAP
> NAME "Bundestagswahlkreise 2002"
> STATUS ON
> EXTENT 5.24 47.29 15.33 55.33
> SIZE 700 700
> FONTSET "/www/fonts/fonts.list"
> IMAGECOLOR 230 230 230
> UNITS DD
> IMAGETYPE GIF
> WEB
> IMAGEPATH "/usr/local/httpd/htdocs/ms_temp/"
> IMAGEURL "http://172.23.71.157/ms_temp/"
> END
> PROJECTION
> "init=epsg:4326"
> #proj=longlat
> #ellps=WGS84
> #datum=WGS84
> #no_defs
> END
> # LAYER
> DEFINITIONEN------------------------------------------------------
> LAYER
> STATUS DEFAULT
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION
> "../../../www/projects/bundestagswahlkreise/data/vektor/wahlkreise
> 2002.tab"
> CLASSITEM "Name"
> TEMPLATE "ttt.html"
> PROJECTION
> "init=epsg:4326"
> #proj=longlat
> #ellps=WGS84
> #datum=WGS84
> #no_defs
> END
> CLASS
> NAME "Wahlkreise"
> EXPRESSION /./
> COLOR 255 255 0
> OUTLINECOLOR 128 128 128
> TEMPLATE "wahlkreise.html"
> END
> END
> END
> +++ GMX - Mail, Messaging & more http://www.gmx.net +++
> Bitte lächeln! Fotogalerie online mit GMX ohne eigene Homepage!
