AW: [Mapserver-users] itemquery on Mapserver 3.6
Thomas Zerweck
tzerweck at zebris.com
Mon Mar 10 08:38:24 EST 2003
the layer is defined by the qlayer-statement, and that seems to work since the selected (wrong) feature is a feature of this layer. The regex stuff might be the problem, since in the doku they say the filter string must be a Mapserver regular expression. However, I tried it with document.mapserv.filter.value="/Munich/" which didn't help. Is there an error in my regular expression?
-----Ursprüngliche Nachricht-----
Von: Michael Schulz [mailto:mschulz at webgis.de]
Gesendet: Montag, 10. März 2003 12:25
An: MapServer Userlist
Betreff: Re: [Mapserver-users] itemquery on Mapserver 3.6
Hi Thomas,
> The javascript executed for example on the onClick-event of a button looks like this:
> function startquery() {
> document.mapserv.target="_self";
> document.mapserv.mode.checked=true;
> document.mapserv.mode.value="itemquery";
> document.mapserv.qlayer.value="cityareas";
> document.mapserv.filteritem.value="NAME";
> document.mapserv.filter.value="Munich";
I think the problem is that you don't refer to a layer specific filter. If you want to assign a filter via URL use this syntax "map_layername_filter=yourfiltervalue". It might also be important to include in your filterstring how to query for results (string, logical, regex
comparison), for regex comparisons you should enclose your statement in //, e.g. "/your_regex/", for logical expression in () for string expressions in "".
HTH, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
