[Mapserver-users] WMS
Marc Jacquin marc.jacquin at geosys-inc.com
Tue Mar 11 04:56:51 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0052_01C2E7BC.EBF58800
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Stefan,
This means that MapServer and PROJ4 cannot find the epsg file. Try to define
a PROJ_LIB environment variable that refers to the directory containing the
epsg file.
Marc
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Stefan
Schwarzer
Sent: mardi 11 mars 2003 10:09
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] WMS
Hi all,
after spending quite some time on this WMS query subject, I am getting a bit
frustrated. I read (almost?) all info on this subject. But still I don't
succeed.
In the moment my computer is nerving me with this message:
Warning: MapServer Error in msProcessProjection(): no system list, errno: 2
in e:\inetpub\wwwroot\geo_map\map.php on line 275
Ok, I know, this is related to the projection list. But: all my other
services (local and WMS-server) are running quite well. So I don't
understand why it's coming up with this message. Below the Layer definition
I use. Any ideas?
Stefan
LAYER
        NAME "test"
        METADATA
                "wms_title" "test"
                "wms_srs" "epsg:4326"
                "wms_connectiontimeout" "1000"
        END
        TYPE RASTER
        STATUS ON
        CONNECTIONTYPE WMS
        CONNECTION "
http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Ci
p%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE
<http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5C
ip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE> "
END
        _______________________________________
        Stefan Schwarzer
        Consultant on GEO
        UNEP/DEWA/GRID-Geneva
        Chemin des Anemones 11
        CH - 1219 Chatelaine
        Switzerland
        Tel: (+41) 22.917.83.49
        Fax: (+41) 22.917.80.29
        Email: stefan.schwarzer at grid.unep.ch
        Internet: http://geodata.grid.unep.ch/
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 9">
<meta name=3DOriginator content=3D"Microsoft Word 9">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C2E7BC.EB87AB00">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:Zoom>0</w:Zoom>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Font Definitions */
@font-face
	{font-family:Tahoma;
	panose-1:2 11 6 4 3 5 4 4 2 4;
	mso-font-charset:0;
	mso-generic-font-family:swiss;
	mso-font-pitch:variable;
	mso-font-signature:16792199 0 0 0 65791 0;}
 /* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0cm;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:blue;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
	{margin:0cm;
	font-size:12.0pt;
p
	{margin-right:0cm;
	mso-margin-top-alt:auto;
	mso-margin-bottom-alt:auto;
	margin-left:0cm;
	font-size:12.0pt;
span.EmailStyle18
	{mso-style-type:personal-reply;
	mso-ansi-font-size:10.0pt;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:navy;}
@page Section1
	{size:595.3pt 841.9pt;
	margin:70.85pt 70.85pt 70.85pt 70.85pt;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
</head>
<body lang=3DEN-GB link=3Dblue vlink=3Dblue =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DEmailStyle18><font size=3D2 =
color=3Dnavy face=3DArial><span
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'>St=
efan,<o:p></o:p></span></font></span></p>
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'><!=
[if =
!supportEmptyParas]>&nbsp;<![endif]><o:p></o:p></span></font></span></p>
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'>Th=
is means
that MapServer and PROJ4 cannot find the epsg file. Try to define a =
PROJ_LIB
environment variable that refers to the directory containing the epsg =
file.<o:p></o:p></span></font></span></p>
[if =
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'>Ma=
rc<o:p></o:p></span></font></span></p>
[if =
<p class=3DMsoNormal style=3D'margin-left:36.0pt'><font size=3D2 =
color=3Dblack
face=3DTahoma><span =
style=3D'font-size:10.0pt;font-family:Tahoma;color:black'>-----Original
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b>
[mailto:mapserver-users-admin at lists.gis.umn.edu]<b><span =
bold'>On Behalf Of </span></b>Stefan Schwarzer<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> mardi 11 mars 2003 =
10:09<br>
<b><span style=3D'font-weight:bold'>To:</span></b>
mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
[Mapserver-users] WMS</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:36.0pt'><font size=3D3
face=3D"Times New Roman"><span style=3D'font-size:12.0pt'><![if =
!supportEmptyParas]>&nbsp;<![endif]><o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:36.0pt'><font size=3D3 =
color=3Dblack
face=3D"Times New Roman"><span style=3D'font-size:12.0pt;color:black'>Hi =
all,<br>
<br>
after spending quite some time on this WMS query subject, I am getting a =
bit
succeed. <br>
<br>
In the moment my computer is nerving me with this message:<br>
<br>
<b><span style=3D'font-weight:bold'>Warning</span></b>: MapServer Error =
in
msProcessProjection(): no system list, errno: 2 in <b><span =
bold'>e:\inetpub\wwwroot\geo_map\map.php</span></b> on line <b><span
style=3D'font-weight:bold'>275</span></b> <br>
<br>
<br>
Ok, I know, this is related to the projection list. But: all my other =
services
(local and WMS-server) are running quite well. So I don't understand why =
it's
coming up with this message. Below the Layer definition I use. Any =
ideas?<br>
<br>
Stefan<br>
<br>
<br>
LAYER<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>NAME
&quot;test&quot;<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>METADATA<b=
r>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nb=
sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_title&quot=
sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_srs&quot;
&quot;epsg:4326&quot;<br>
sp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_connection=
timeout&quot;
&quot;1000&quot;<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>END<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>TYPE =
RASTER<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>STATUS =
ON<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CONNECTION=
TYPE
WMS<br>
 &quot;<a
href=3D"http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=3De%3A%5Cinetpub%=
5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=3D1.0.0&amp;LAYERS=3Dpeople&amp;FORM=
AT=3DPNG&amp;TRANSPARENT=3DTRUE"
eudora=3Dautourl>http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=3De%3A%5=
Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=3D1.0.0&amp;LAYERS=3Dpeople=
&amp;FORMAT=3DPNG&amp;TRANSPARENT=3DTRUE</a>&quot;<br>
END<br>
<br style=3D'mso-special-character:line-break'>
<![if !supportLineBreakNewLine]><br =
<![endif]></span></font><font color=3Dblack><span =
style=3D'color:black;mso-color-alt:
windowtext'><o:p></o:p></span></font></p>
<x-sigsep>
<p style=3D'margin-left:36.0pt'></x-sigsep><font size=3D3 color=3Dblack
face=3D"Times New Roman"><x-tab><span =
style=3D'font-size:12.0pt;color:black'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;&nbsp;</x-tab>_______________________________________<br>
<br>
</span><x-tab></font><font size=3D2 color=3Dblack><span =
color:black'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><b><=
span
style=3D'font-weight:bold'>Stefan Schwarzer<br>
</span></b><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab=
>Consultant
on GEO<br>
<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>UNEP/DEWA/=
GRID-Geneva<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Chemin =
des
Anemones 11<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CH - 1219
Chatelaine<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Switzerlan=
d<br>
<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Tel: =
(+41)
22.917.83.49<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Fax: =
(+41)
22.917.80.29<br>
<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Email:
stefan.schwarzer at grid.unep.ch<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Internet: =
<a
href=3D"http://geodata.grid.unep.ch/" =
eudora=3Dautourl>http://geodata.grid.unep.ch/</a><br>
</span><x-tab></font><font color=3Dblack><span =
style=3D'color:black'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x=
-tab>_______________________________________</span></font><font
style=3D'color:black;mso-color-alt:windowtext'><o:p></o:p></span></font><=
/p>
</div>
</body>
</html>
------=_NextPart_000_0052_01C2E7BC.EBF58800--
