[Mapserver-users] WMS
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Tue Mar 11 10:02:28 EST 2003
--=====================_114741739==.ALT
Content-Type: text/plain; charset="us-ascii"; format=flowed
Ed,
no, I am getting no more errors. The layer just does not appear. The layer
is turned on, and as you said, not only because of STATUS ON, but in my PHP
script I tell explicitly to turn it on again (actually after turning all
layers off):
$mapLayer = $map -> getlayerbyname("test");
$mapLayer -> set("status", 1);
Where does the "wms_title" refer to? Should it have the same title as the
WMS service layer? What is TYPE in this case? Originally it's a POINT
shapefile, but now it would be anyway a raster/image, no? When I try to
display the layer locally, everything turns up nicely.
LAYER
NAME 'test'
METADATA
'wms_title' 'test'
'wms_srs' 'epsg:4326'
'wms_connectiontimeout' '1000'
END
TYPE POINT
STATUS ON
CONNECTIONTYPE WMS
CONNECTION
'http://gridss.grid.unep.ch/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE'
END
Ciao,
Stefan
>Stefan -
>You can certainly use multiple local and remote layers.
>Now that the PROJ problem is fixed, are you getting any errors? Is the
>layer simply not appearing? Is the layer turned on (STATUS ON isn't enough)?
> - Ed
>-----Original Message-----
>From: Stefan Schwarzer [mailto:stefan.schwarzer at grid.unep.ch]
>Sent: Tuesday, March 11, 2003 9:36 AM
>To: Ed McNierney; mapserver-users at lists.gis.umn.edu
>Subject: RE: [Mapserver-users] WMS
>Ed,
>thanks for the quick answer. But the answer is: yes... As the WMS service
>from where I want to retrieve a layer, does for sure work as it has been
>implemented into another application, the problem can hardly be on this
>side. I think, something is wrong on the map-file side. As the BBox and
>other parameters are produced automatically by MapServer, the URL used in
>the CONNECTION line below should be correct...
>Just to be sure: Can I have a map-file with multiple local layers, which
>are accessed normally, and in addition a couple of WMS layers, accessed as
>shown below? I was just wondering if MapServer would be capable of merging
>then two, three or four different images, as each WMS service sends its
>own image back. I know that I can overlay different requests and thus
>images using simple HTML code, but I am not so sure about the method I
>just wanted to implement. Stupid question? Hmmm...
>Ciao,
>Stefan
>>Stefan -
>>We don't know what your data are, so we can't tell whether the metadata
>>(the projection in particular) are correct - you need to check that. You
>>also need to be requesting map extents (the WMS BBox) in coordinates that
>>match both the projection of your map and the extents of your data.
>> - Ed
>>Ed McNierney
>>President and Chief Mapmaker
>>TopoZone.com / Maps a la carte, Inc.
>>73 Princeton Street, Suite 305
>>North Chelmsford, MA 01863
>>ed at topozone.com
>>(978) 251-4242
>>Sent: Tuesday, March 11, 2003 9:11 AM
>>To: mapserver-users at lists.gis.umn.edu
>>Hi all,
>>thanks for the input. Right, after setting an environment variable the
>>ugly warning disappeared.
>>But I have still the problem that the WMS layer is not showing up. Any
>>hints into this direction? Are the Metadata in the Layer definition
>>correct? Do I have to define anything else in the mapfile? [I am working
>>with MapScript, v3.5]
>>Thanks,
>>Stefan
>>>Stefan -
>>>Marc's response is correct; you will find information about this problem
>>>in the "FAQ / Common Problems" section of the WMS Server page at
>>><http://mapserver.gis.umn.edu/doc/wms-server-howto.html>http://mapserver.gis.umn.edu/doc/wms-server-howto.html
>>> - Ed
>>>Ed McNierney
>>>ed at topozone.com
>>>(978) 251-4242
>>>Sent: Tuesday, March 11, 2003 4:09 AM
>>>Subject: [Mapserver-users] WMS
>>>Hi all,
>>>after spending quite some time on this WMS query subject, I am getting a
>>>bit frustrated. I read (almost?) all info on this subject. But still I
>>>don't succeed.
>>>In the moment my computer is nerving me with this message:
>>>Warning: MapServer Error in msProcessProjection(): no system list,
>>>errno: 2 in e:\inetpub\wwwroot\geo_map\map.php on line 275
>>>Ok, I know, this is related to the projection list. But: all my other
>>>services (local and WMS-server) are running quite well. So I don't
>>>understand why it's coming up with this message. Below the Layer
>>>definition I use. Any ideas?
>>>Stefan
>>>LAYER
>>> NAME "test"
>>> METADATA
>>> "wms_title" "test"
>>> "wms_srs" "epsg:4326"
>>> "wms_connectiontimeout" "1000"
>>> END
>>> TYPE RASTER
>>> STATUS ON
>>> CONNECTIONTYPE WMS
>>> CONNECTION
>>> "http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE"
>>>END
>>> _______________________________________
>>> Stefan Schwarzer
>>> Consultant on GEO
>>> UNEP/DEWA/GRID-Geneva
>>> Chemin des Anemones 11
>>> CH - 1219 Chatelaine
>>> Switzerland
>>> Tel: (+41) 22.917.83.49
>>> Fax: (+41) 22.917.80.29
>>> Email: stefan.schwarzer at grid.unep.ch
>>> Internet: http://geodata.grid.unep.ch/
>> Stefan Schwarzer
>> Consultant on GEO
>> Switzerland
> Stefan Schwarzer
> Consultant on GEO
> Switzerland
Stefan Schwarzer
Consultant on GEO
Switzerland
Content-Type: text/html; charset="us-ascii"
<html>
<body>
<font size=3>Ed,<br><br>
layer is turned on, and as you said, not only because of STATUS ON, but
in my PHP script I tell explicitly to turn it on again (actually after
turning all layers off):<br><br>
$mapLayer = $map -> getlayerbyname("test");<br>
$mapLayer -> set("status", 1);<br><br>
title as the WMS service layer? What is TYPE in this case? Originally
it's a POINT shapefile, but now it would be anyway a raster/image, no?
When I try to display the layer locally, everything turns up
nicely.<br><br>
LAYER<br>
<x-tab> </x-tab>NAME
'test'<br>
<x-tab> </x-tab>METADATA<br>
<x-tab> </x-tab><x-tab> </x-tab>'wms_title'
'test'<br>
<x-tab> </x-tab><x-tab> </x-tab>'wms_srs'
'epsg:4326'<br>
<x-tab> </x-tab><x-tab> </x-tab>'wms_connectiontimeout'
'1000'<br>
<x-tab> </x-tab>END<br>
<x-tab> </x-tab>TYPE
POINT<br>
<x-tab> </x-tab>STATUS
ON<br>
<x-tab> </x-tab>CONNECTIONTYPE
WMS<br>
'<a href="http://gridss.grid.unep.ch/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE" eudora="autourl">http://gridss.grid.unep.ch/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE</a>'<br>
END<br><br>
<br>
Ciao,<br><br>
Stefan<br><br>
<br>
</font><blockquote type=cite class=cite cite><font face="arial" size=2 color="#0000FF">Stefan
-</font><font size=3><br>
<br>
</font><font face="arial" size=2 color="#0000FF">You can certainly
use multiple local and remote layers.</font><font size=3><br>
<br>
</font><font face="arial" size=2 color="#0000FF">Now that the PROJ
problem is fixed, are you getting any errors? Is the layer simply
enough)?</font><font size=3><br>
<br>
</font><font face="arial" size=2 color="#0000FF"> -
Ed</font><font size=3><br>
</font>
<dl>
<dd><font face="tahoma" size=2>-----Original Message-----<br>
<dd>From:</b> Stefan Schwarzer
[<a href="mailto:stefan.schwarzer at grid.unep.ch" eudora="autourl">mailto:stefan.schwarzer at grid.unep.ch</a>]<br>
<dd>Sent:</b> Tuesday, March 11, 2003 9:36 AM<br>
<dd>To:</b> Ed McNierney; mapserver-users at lists.gis.umn.edu<br>
<dd>Subject:</b> RE: [Mapserver-users] WMS<br><br>
</font>
<dd><font size=3>Ed,<br><br>
<dd>thanks for the quick answer. But the answer is: yes... As the WMS
service from where I want to retrieve a layer, does for sure work as it
has been implemented into another application, the problem can hardly be
on this side. I think, something is wrong on the map-file side. As the
BBox and other parameters are produced automatically by MapServer, the
URL used in the CONNECTION line below should be correct...<br><br>
<dd>Just to be sure: Can I have a map-file with multiple local layers,
which are accessed normally, and in addition a couple of WMS layers,
accessed as shown below? I was just wondering if MapServer would be
capable of merging then two, three or four different images, as each WMS
service sends its own image back. I know that I can overlay different
requests and thus images using simple HTML code, but I am not so sure
about the method I just wanted to implement. Stupid question?
Hmmm...<br><br>
<dd>Ciao,<br><br>
<dd>Stefan<br><br>
<br>
<dd><font face="arial" size=2 color="#0000FF">Stefan
<dd> <br>
</font>
<dd><font face="arial" size=2 color="#0000FF">We don't know what your
data are, so we can't tell whether the metadata (the projection in
particular) are correct - you need to check that. You also need to
be requesting map extents (the WMS BBox) in coordinates that match both
data.</font><font size=3><br>
<dd> <br>
<dd> </font><font face="arial" size=2 color="#0000FF">-
Ed</font><font size=3><br><br>
</font>
<dd><font size=2>Ed McNierney<br>
<dd>President and Chief Mapmaker<br>
<dd>TopoZone.com / Maps a la carte, Inc.<br>
<dd>73 Princeton Street, Suite 305<br>
<dd>North Chelmsford, MA 01863<br>
<dd>ed at topozone.com<br>
<dd>(978) 251-4242 </font>
<dd>From: Stefan Schwarzer
<dd>Sent: Tuesday, March 11, 2003 9:11 AM
<dd>To: mapserver-users at lists.gis.umn.edu
<dd>Subject: RE: [Mapserver-users] WMS<br><br>
</font>
<dd><font size=3>Hi all,<br>
<dd>thanks for the input. Right, after setting an environment variable
the ugly warning disappeared.<br>
<dd>But I have still the problem that the WMS layer is not showing up.
Any hints into this direction? Are the Metadata in the Layer definition
with MapScript, v3.5]<br>
<dd>Thanks,<br>
<dd>Stefan<br>
<br><br>
<dd> </font>
<dd><font face="arial" size=2 color="#0000FF">Marc's response is correct;
you will find information about this problem in the "FAQ / Common
<a href="http://mapserver.gis.umn.edu/doc/wms-server-howto.html">http://mapserver.gis.umn.edu/doc/wms-server-howto.html</a></font><font size=3><br>
<dd>
</font>
<dd>Sent: Tuesday, March 11, 2003 4:09 AM
<dd>Subject: [Mapserver-users] WMS<br><br>
</font>
<dd>after spending quite some time on this WMS query subject, I am
getting a bit frustrated. I read (almost?) all info on this subject. But
still I don't succeed.
<dd>In the moment my computer is nerving me with this message:
<dd>Warning: MapServer Error in msProcessProjection(): no system list,
errno: 2 in e:\inetpub\wwwroot\geo_map\map.php on line 275 <br>
<dd>Ok, I know, this is related to the projection list. But: all my other
<dd>Stefan<br>
<dd>LAYER
<dd><x-tab> </x-tab>NAME
"test"
<dd><x-tab> </x-tab>METADATA
<dd><x-tab> </x-tab><x-tab> </x-tab>"wms_title"
"test"
<dd><x-tab> </x-tab><x-tab> </x-tab>"wms_srs"
"epsg:4326"
<dd><x-tab> </x-tab><x-tab> </x-tab>"wms_connectiontimeout"
"1000"
<dd><x-tab> </x-tab>END
<dd><x-tab> </x-tab>TYPE
RASTER
<dd><x-tab> </x-tab>STATUS
ON
<dd><x-tab> </x-tab>CONNECTIONTYPE
WMS
"<a href="http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE" eudora="autourl">http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE</a>"
<dd>END
<dd><x-tab> </x-tab>_______________________________________<br><br>
</font>
<dd><font size=2><x-tab> </x-tab>Stefan
Schwarzer
<dd><x-tab> </x-tab>Consultant
on GEO
<dd><x-tab> </x-tab>UNEP/DEWA/GRID-Geneva
<dd><x-tab> </x-tab>Chemin
des Anemones 11
<dd><x-tab> </x-tab>CH -
1219 Chatelaine
<dd><x-tab> </x-tab>Switzerland
<dd><x-tab> </x-tab>Tel:
(+41) 22.917.83.49
<dd><x-tab> </x-tab>Fax:
(+41) 22.917.80.29
<dd><x-tab> </x-tab>Email:
<dd><x-tab> </x-tab>Internet:
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a></font><font size=3>
</blockquote>
</dl><br>
</font><font size=2><x-tab> </x-tab>Stefan
Schwarzer<br>
on GEO<br><br>
<x-tab> </x-tab>UNEP/DEWA/GRID-Geneva<br>
<x-tab> </x-tab>Chemin des
Anemones 11<br>
<x-tab> </x-tab>CH - 1219
Chatelaine<br>
<x-tab> </x-tab>Switzerland<br><br>
<x-tab> </x-tab>Tel: (+41)
22.917.83.49<br>
<x-tab> </x-tab>Fax: (+41)
22.917.80.29<br><br>
stefan.schwarzer at grid.unep.ch<br>
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a><br>
</font><font size=3><x-tab> </x-tab>_______________________________________
</blockquote><br>
Schwarzer<br>
</b><x-tab> </x-tab>Consultant
on GEO<br><br>
Anemones 11<br>
Chatelaine<br>
22.917.83.49<br>
<br>
</font></blockquote>
<x-sigsep><p></x-sigsep>
<font size=3><x-tab> </x-tab>_______________________________________<br><br>
</font><font size=2><x-tab> </x-tab><b>Stefan
Schwarzer<br>
on GEO<br><br>
Anemones 11<br>
Chatelaine<br>
22.917.83.49<br>
</font><font size=3><x-tab> </x-tab>_______________________________________</font></body>
</html>
--=====================_114741739==.ALT--
