[Mapserver-users] why does my raster layer turn my shapefile layer gray?
Chris Black cblack at CalAcademy.Org
Tue Mar 11 13:44:04 EST 2003
--------------040508010700000907040305
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Thanks, Ed and Dylan; my problem is solved.  I added the following to my
map file:
OUTPUTFORMAT
  NAME png24bit
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE RGB
END
And this to my php script:
$map->selectOutputFormat('png24bit');
Performance is slower, naturally, now that the images have more than
doubled in size.  I was *not* successful with adding 'PROCESSING
"COLOR_MATCH_THRESHOLD=3"', as my 3.7 build isn't new enough (I pulled
mapserver-3.7-win32-php4.3.0-gd2.zip
<http://www2.dmsolutions.ca/mapserver/dl/mapserver-3.7-win32-php4.3.0-gd2.zip>
from  http://www2.dmsolutions.ca/mapserver/dl/ ; it's dated 10-Feb-2003.
 I don't want to get into the business of doing my own builds if I can
help it (I'm on Windows; on *n*x I wouldn't mind so much), so I'll take
the performance hit for now.
Thanks again.
-- Chris
Ed McNierney wrote:
>Chris -
>Today must be "I ran out of colors" Day <g>.
>This is the same issue Aaron Hunt posted under "TRANSPARENCY problem",
>and was discussed under "COLOR_MATCH_THRESHOLD" a few days ago.
>You're running out of colors in your 8-bit output image.  MapServer
>renders one layer at a time, starting from the beginning of your MAP
>file, and allocates new colors as needed by each layer.  After you've
>drawn enough layers to use 256 distinct colors, all subsequent layers
>are stuck with the 256 colors already defined, and MapServer chooses the
>closest fit.
>If you display just the "baylands" layer, you use up two colors - two
>shades of blue.  If you display just the "bayraster" layer, you get (I
>presume) 256 shades of gray.
>If you display the "bayraster" layer AND the "baylands" layer, the
>"bayraster" layer allocates 256 shades of gray, and there aren't any
>more palette colors available to create shades of blue - so the
>"baylands" layer is drawn using the shades of gray closest to those two
>shades of blue.  And that's not very close.
>Solution path #1 - Use the OUTPUTFORMAT block in 3.7 to create a 24-bit
>output image.  You will then get much larger map images, but you will no
>longer be constrained to the 256 colors in an 8-bit image.
>Solution path #2 - If you're using GDAL to read raster layers, see the
>mailing list for the COLOR_MATCH_THRESHOLD statement, which will cause
>MapServer to select a "close" match instead of an exact match when
>allocating colors for the raster layer.  This will result in an
>on-the-fly reduction in the number of colors used by your raster layer;
>instead of using up a different palette entry for every unique shade of
>gray, MapServer will consider a near match to be "close enough" and use
>that existing shade of gray.  This will mean that there are some palette
>colors still available when you get around to drawing the "baylands"
>layer.
>	- Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA  01863
>Phone: (978) 251-4242  Fax: (978) 251-1396
>ed at topozone.com
>-----Original Message-----
>From: Chris Black [mailto:cblack at CalAcademy.Org]
>Sent: Monday, March 10, 2003 8:44 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] why does my raster layer turn my shapefile
>layer gray?
>Hello all,
>I have a map with two layers: one is an ArcView grid file that is a
>relief map of the SF Bay Area in various shades of gray.  The other is a
>shapefile that show the bay waters in two classes, shallow and deep.  If
>I display just the shapefile layer ("Baylands" in the mapfile below),
>these two classes are two different shades of blue.  If I display the
>raster layer ("bayraster") as well, the classes are changed to shades of
>gray.  Why does it happen, and how can I get my colors back?
>Much thanks for any help.
>-- Chris
>Mapserver version string:  "MapServer version 3.7 (development)
>OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ
>SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>SUPPORTS=GD2_RGB INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE"
>I view the map with the url
>"http://localhost/Scripts/mapserv.exe?map=C:/inetpub/wwwroot/mapserverap
>ps/IZG/testraster.map&mode=map"
>testraster.map:
>--------------- cut here ----------------------
># Note: Comments in a map file are preceeded by the pound (#) sign.
># When MapServer encounters the pound sign, it will ignore the
># rest of the line.  Unfortunately, you can't comment a whole block
># of code or text in MapServer.  So, you're stuck with adding pound
># signs for every line you wish to comment out.
>NAME CALCTYEX1
>EXTENT 467416 4085763 623532 4288980
>SIZE 350 300
>UNITS METERS
>SHAPEPATH "C:\inetpub\wwwroot\MapServerApps\IZG\data\"
>SYMBOLSET "C:\inetpub\wwwroot\MapServerApps\symbols\symbols.sym"
>LAYER
>    data "c:\inetpub\wwwroot\sfbay\data\EcoAtlas\grid\sfbayshr"
>    NAME "bayraster"
>    STATUS DEFAULT
>    TYPE RASTER
>    CLASS
>        NAME "Relief Map"
>    END # CLASS
>END # LAYER
>LAYER
>    NAME "Baylands"
>    DATA "vector\mbypsfby"
>    STATUS DEFAULT
>    TYPE POLYGON
>    CLASS
>        NAME "Deep Bay"
>        EXPRESSION ('[ENTITYID]' = 'A00000000000')
>        COLOR 51 51 255
>    END # CLASS
>    CLASS
>        NAME "Shallow Bay"
>        EXPRESSION ('[ENTITYID]' = 'A10000000000' OR '[ENTITYID]' =
>'A10000000090' OR '[ENTITYID]' = 'B4ST00000000')
>        COLOR 102 102 204
>    END # CLASS
>END # LAYER
>END # FILE
>--------------- cut here ----------------------------
>I don't understand grid files very well, so here's the listing of the
>grid directory and its children in case something is wrong there (though
>I don't think so, since the grid itself displays ok):
>C:/Inetpub/wwwroot/sfbay/data/EcoAtlas/grid:
>info
>sfbayshr
>sfbayshr.met
>sfbayshrw
>sfbr-sr-dbdesc.txt
>C:/Inetpub/wwwroot/sfbay/data/EcoAtlas/grid/info:
>arc.dir
>arc0000.dat
>arc0000.nit
>arc0001.dat
>arc0001.nit
>arc0002.dat
>arc0002.nit
>arc0002r.001
>C:/Inetpub/wwwroot/sfbay/data/EcoAtlas/grid/sfbayshr:
>dblbnd.adf
>hdr.adf
>log
>prj.adf
>sta.adf
>vat.adf
>w001001.adf
>w001001x.adf
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
  <title></title>
</head>
<body>
Thanks, Ed and Dylan; my problem is solved. &nbsp;I added the following to my
map file:<br>
<br>
OUTPUTFORMAT<br>
&nbsp; NAME png24bit<br>
&nbsp; DRIVER "GD/PNG"<br>
&nbsp; MIMETYPE "image/png"<br>
&nbsp; IMAGEMODE RGB<br>
END<br>
<br>
And this to my php script:<br>
<br>
$map-&gt;selectOutputFormat('png24bit');<br>
<br>
Performance is slower, naturally, now that the images have more than doubled
in size. &nbsp;I was *not* successful with adding 'PROCESSING "COLOR_MATCH_THRESHOLD=3"',
as my 3.7 build isn't new enough (I pulled&nbsp; <a
 href="http://www2.dmsolutions.ca/mapserver/dl/mapserver-3.7-win32-php4.3.0-gd2.zip">mapserver-3.7-win32-php4.3.0-gd2.zip</a>
 from &nbsp;<a class="moz-txt-link-freetext" href="http://www2.dmsolutions.ca/mapserver/dl/">http://www2.dmsolutions.ca/mapserver/dl/</a> ; it's dated 10-Feb-2003.
&nbsp;I don't want to get into the business of doing my own builds if I can help
it (I'm on Windows; on *n*x I wouldn't mind so much), so I'll take the performance
hit for now.<br>
<br>
Thanks again.<br>
<br>
-- Chris<br>
<br>
Ed McNierney wrote:<br>
<blockquote type="cite"
 cite="mid13858AA1A74F30419F319ACB66A9D12201962E at mercator.topozone.com">
  <pre wrap="">Chris -
Today must be "I ran out of colors" Day &lt;g&gt;.
closest fit.
layer.
	- Ed
Ed McNierney
<a class="moz-txt-link-abbreviated" href="mailto:ed at topozone.com">ed at topozone.com</a>
From: Chris Black [<a class="moz-txt-link-freetext" href="mailto:cblack at CalAcademy.Org">mailto:cblack at CalAcademy.Org</a>]
To: <a class="moz-txt-link-abbreviated" href="mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.gis.umn.edu</a>
layer gray?
Hello all,
-- Chris
<a class="moz-txt-link-rfc2396E" href="http://localhost/Scripts/mapserv.exe?map=C:/inetpub/wwwroot/mapserverapps/IZG/testraster.map&mode=map">"http://localhost/Scripts/mapserv.exe?map=C:/inetpub/wwwroot/mapserverap
ps/IZG/testraster.map&amp;mode=map"</a>
testraster.map:
NAME CALCTYEX1
SIZE 350 300
UNITS METERS
LAYER
    NAME "bayraster"
    STATUS DEFAULT
    TYPE RASTER
    CLASS
        NAME "Relief Map"
    END # CLASS
END # LAYER
LAYER
    NAME "Baylands"
    STATUS DEFAULT
    TYPE POLYGON
    CLASS
        NAME "Deep Bay"
        COLOR 51 51 255
    END # CLASS
    CLASS
        NAME "Shallow Bay"
        COLOR 102 102 204
    END # CLASS
END # LAYER
END # FILE
info
sfbayshr
sfbayshr.met
sfbayshrw
sfbr-sr-dbdesc.txt
arc.dir
arc0000.dat
arc0000.nit
arc0001.dat
arc0001.nit
arc0002.dat
arc0002.nit
arc0002r.001
dblbnd.adf
hdr.adf
log
prj.adf
sta.adf
vat.adf
w001001.adf
w001001x.adf
<a class="moz-txt-link-abbreviated" href="mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.gis.umn.edu</a>
<a class="moz-txt-link-freetext" href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a>
  </pre>
</blockquote>
<br>
</body>
</html>
--------------040508010700000907040305--
