[Mapserver-users] projection problem
Stepan Kafka
stepan.kafka at centrum.cz
Tue Mar 11 15:25:29 EST 2003
You have set the map extent still in WGS 84 lat/lon coordinates. You must
change them to Gauss Kruger ones. Also units meters...
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: frauke.trurnit at gmx.de [mailto:frauke.trurnit at gmx.de]
> Odesláno: 11. bøezna 2003 8:48
> Komu: mapserver-users at lists.gis.umn.edu
> Kopie: arnulf.christl at ccgis.de; stepan.kafka at centrum.cz
> Pøedmìt: Re: [Mapserver-users] projection problem
> Hi Anrulf, hi Stepan,
> If I use Gauß-Krüger (init=EPSG:31493), no more map appears.
> Frauke
> NAME 'Bundestagswahlkreise 2002'
> STATUS ON
> EXTENT 5.24 47.29 15.33 55.33
> UNITS dd
> PROJECTION
> 'init=epsg:31493'
> END
> LAYER
> TYPE POLYGON
> STATUS ON
> DATA 'wahlkreise2002'
> PROJECTION
> 'init=epsg:4326'
> END
> CLASSITEM 'Name'
> CLASS
> NAME 'Wahlkreise'
> EXPRESSION /./
> OUTLINECOLOR 128 128 128
> COLOR 255 255 0
> TEMPLATE 'wahlkreise.html'
> END
> END
> > Hi,
> > the map looks correct - just like specified with 4326 which ist
> "ETRS89".
> > If
> > you want to have it look like we are used to in Germany you have to
> > project
> > it in Gauß-Krüger or similar.
> > Regards, Arnulf.
> > MAP
> > NAME "Germany"
> > STATUS ON
> > #EXTENT 5.88 46.6213 15 55.7187
> > EXTENT 2886610 5230448 4285190 6130010 #5.88 46.6213 15 55.7187
> > PROJECTION
> > "init=EPSG:31493" # projection of the whole
> > project
> > END
> > LAYER
> > NAME "Topographie"
> > STATUS ON
> > DATA "d:/umn/data/hynet_polygon.shp"
> > TYPE POLYGON
> > TEMPLATE "templates/query.html"
> > HEADER "templates/query_header.html"
> > FOOTER "templates/query_footer.html"
> > TOLERANCE 20
> > TOLERANCEUNITS PIXELS
> > PROJECTION
> > "init=EPSG:4326" # projection of the data
> > END
> > CLASSITEM "HYPYTYPE"
> > UNITS METERS
> > SIZEUNITS PIXELS
> +++ GMX - Mail, Messaging & more http://www.gmx.net +++
> Bitte lächeln! Fotogalerie online mit GMX ohne eigene Homepage!
