[Mapserver-users] ArcExplorer 4.0.1 WMS Client
Daryl Herzmann akrherz at iastate.edu
Fri Mar 14 13:53:04 EST 2003
Hi!
Are you using the WMS extension or trying to connect to a ArcIMS server?
The com.esri.esrimap.Esrimap URL would indicate you tried to connect to an
ArcIMS server instead of using the WMS extension...
HTH,
  Daryl
On Fri, 14 Mar 2003 Antti.Roppola at brs.gov.au wrote:
>Any further info/details on getting this to work this would be appreciated.
>I just tried various incantations with 3.6 and 3.7 but no luck. My server
>logs do show Arc Explorer trying to GET ".esrimap",
>"/servlet/com.esri.esrimap.Esrimap" and "/scripts/esrimap.dll".
>Cheers,
>Antti
>-----Original Message-----
>From: Daryl Herzmann [mailto:akrherz at iastate.edu]
>Sent: Friday, 14 March 2003 9:39 AM
>To: Daniel Morissette
>Cc: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] ArcExplorer 4.0.1 WMS Client
>Hi,
>Thanks for the continued help!  As a test, I took the XML output and
>manually changed it to version 1.1.1 and then wrapped it in a PHP script.
><?php
>  header("Content-type: application/vnd.ogc.gml");
>............my xml file here........
>And this works!  Fancy, Fancy!!  So my conclusion is that ArcExplorer
>needs version 1.1.1 over 1.1.0
>Thanks!
>  Daryl
>On Thu, 13 Mar 2003, Daniel Morissette wrote:
>>Daryl Herzmann wrote:
>>> Do I need to upgrade to 3.7 dev to get 1.1.1 support?  Or should I
>>> downgrade to 1.0.0 to get this to work?  Looking at the Extension FAQ,
>>> perhaps this beast only supports 1.0.0 and 1.1.1 ??
>>3.7 doesn't support 1.1.1 either.  I was convinced that I had upgraded
>>it to 1.1.1, but I double-checked a few minutes ago and it seems that I
>>haven't, Duh!  One more thing for the ToDo list!
 * Daryl Herzmann (akrherz at iastate.edu)
 * Program Assistant -- Iowa Environmental Mesonet
 * http://mesonet.agron.iastate.edu
