[Mapserver-users] GIS Student needs help
Krung Saengpole
krung at cad.go.th
Sun Mar 16 14:16:28 EST 2003
Try full path to map file,
<img border="1"src="/cgi-bin/mapserv.exe?E:/Apache+Group/Apache2/htdocs/hall/single.map&mode=map">
notice '+' in your path, it's for space in url format.
Krung
---------- Original Message ----------------------------------
Date: Fri, 14 Mar 2003 22:16:37 -0500
>I've removed the comment and corrected the the scr to:
><img border="1"src="/cgi-bin/mapserv.exe?map=/hall/single.map&mode=map">
>I still cannot see the shp file. Can you guys help me again?
>George
>From: "Krung Saengpole" <krung at cad.go.th>
>To: <mapserver-users at lists.gis.umn.edu>
>Sent: Friday, March 14, 2003 7:49 PM
>Subject: Re: [Mapserver-users] GIS Student needs help
>> George,
>> Also you have to change src attribute to use your mapserver program with
>your platform, e.g.
>> <img .... src="/cgi-bin/mapserv.exe?map=.....">
>> because in Windows, mapserver program is mapserv.exe. Demo setting is for
>*n*x.
>> Krung
>> >George,
>> >For starters, your LAYER line is commented out. Remove the leading #
>> >from LAYER.
>> >--Dylan
>> >George McCown wrote:
>> >> I've successfully installed the demo map server on apache 2.
>> >> Now I want to learn how to make single layers but I need more help
>> >> than what the Tutorial shows.
>> >> data file: E:\Apache Group\Apache2\htdocs\hall\data\states.shp
>> >> mapserv(3.6): E:\Apache Group\Apache2\cgi-bin
>> >> single.map and single.html: E:\Apache Group\Apache2\htdocs\hall
>> >> ********* Single.html**********************
>> >> <html>
>> >> <head>
>> >> <title>single</title>
>> >> </head>
>> >> <body>
>> >> <h1>SINGLE LAYER</h1>
>> >> <img border="1"
>src="="/cgi-bin/mapserv35?map/hall/single.map&mode=map">
>> >> <p>why is it mapserv35?map not just mapserv.exe?</p>
>> >> </body>
>> >> </html>
>> >> ************single.map*****************
>> >> NAME test
>> >> EXTENT -127.92 49.47 -77.05 23.66
>> >> SIZE 400 300
>> >> SHAPEPATH "data"
>> >> #LAYER # start of the "states" layer object
>> >> NAME "states"
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
