[Mapserver-users] Labels
João Paulo M. Claro
jpmclaro at yahoo.com.br
Mon Mar 17 15:11:32 EST 2003
Jim,
With its tip it was good, more observes that labels is under the streets in
the crossings. This is my main problem.
Link:
http://200.231.117.203/cgi-bin/mapserv?mode=browse&zoomdir=1&zoomsize=1&imgx
y=-46.65317+-23.55735&imgext=-46.65796623+-23.56054931+-46.64837377+-23.5541
5069&map=c:/apps/maplab-2.0rc3/itasca/municipios.map&program=/cgi-bin/mapser
v&map_web_imagepath=/tmp/ms_tmp/&map_web_imageurl=/ms_tmp/&img.x=300&img.y=2
00
Thanks
João Paulo
----- Original Message -----
From: "James Jefferson" <jjeffers at aprsworld.net>
To: "João Paulo M. Claro" <jpmclaro at yahoo.com.br>
Sent: Monday, March 17, 2003 10:55 AM
Subject: Re: [Mapserver-users] Labels
> Well, it looks like the labels are appearing above the street, but the
> problem is that you are getting labels that are too close together and are
> therefore overlapping. Try doing this:
> MINFEATURESIZE 50
> MINDISTANCE 150
> That should go in the label part.
> -Jim
> On Monday 17 March 2003 01:53 pm, you wrote:
> > Dear James,
> > The problem persists, follows below the configuration that I am using,
and
> > link with the resultant map. Please, it sees if it can help me.
> > LAYER
> > NAME "Ruas_sp"
> > STATUS DEFAULT
> > TYPE LINE
> > CONNECTIONTYPE OGR
> > CONNECTION "../mapa/Data/SP/Rua.TAB"
> > UNITS METERS
> > SIZEUNITS PIXELS
> > MINSCALE 0
> > MAXSCALE 10
> > LABELITEM "Rua"
> > LABELCACHE OFF
> > POSTLABELCACHE TRUE
> > TOLERANCE 7
> > TOLERANCEUNITS PIXELS
> > TEMPLATE "ttt.html"
> > CLASS
> > NAME "Ruas_sp"
> > MINSCALE 0
> > MAXSCALE 10
> > SYMBOL 7
> > COLOR 0 0 0
> > SIZE 5
> > MINSIZE 1
> > MAXSIZE 100
> > OVERLAYSYMBOL 7
> > OVERLAYCOLOR 255 255 255
> > OVERLAYSIZE 3
> > LABEL
> > TYPE TRUETYPE
> > FONT "arial"
> > SIZE 8
> > MINSIZE 4
> > MAXSIZE 256
> > POSITION UC
> > OFFSET 3 3
> > ANGLE AUTO
> > BUFFER 7
> > MINDISTANCE 10
> > MINFEATURESIZE AUTO
> > COLOR 0 0 0
> > SHADOWCOLOR 0 0 0
> > SHADOWSIZE 0 0
> > PARTIALS FALSE
> > END
> > END
> > END
>xy=-46.65317+-23.55735&imgext=-46.65796623+-23.56054931+-46.64837377+-23.55
4
>15069&map=c:/apps/maplab-2.0rc3/itasca/municipios.map&program=/cgi-bin/maps
e
>rv&map_web_imagepath=/tmp/ms_tmp/&map_web_imageurl=/ms_tmp/&img.x=300&img.y
> >200
> > Thanks,
> > João Paulo.
> > Sent: Monday, March 17, 2003 9:35 AM
> > > Use the POSITION keyword. To make it centered and above the line, you
> > > would use
> > > POSITION UC
> > > here is an example of how I use it:
> > > # Rural principal arteries, Urban Principal Arteries
> > > CLASS
> > > EXPRESSION ( [FEAT_CLASS] = 2 OR [FEAT_CLASS] = 14 )
> > > COLOR 128 128 128
> > > LABEL
> > > MINFEATURESIZE 50
> > > MINDISTANCE 150
> > > TYPE TRUETYPE
> > > FONT "verdana"
> > > SIZE 8
> > > COLOR 0 0 0
> > > POSITION UC # above line
> > > ANGLE AUTO
> > > END
> > > END
> > > On Monday 17 March 2003 11:26 am, you wrote:
> > > > Hi folks,
> > > > I am with problems in my labels, they appear in low of the lines of
the
> > > > streets, somebody knows as to decide this problem?
> > > > Thanks,
> > > > João Paulo
_______________________________________________________________________
Busca Yahoo!
O serviço de busca mais completo da Internet. O que você pensar o Yahoo! encontra.
http://br.busca.yahoo.com/
