[Mapserver-users] Fw: Mapscript from command line
Paul Dymecki millardymecki at sympatico.ca
Tue Mar 18 13:46:49 EST 2003
 Hi all,
     I'm finally running a mapscript program from the command line, but have
had to remove my projection object(init=epsg:42304) from the map file to get
it to work.  Does anyone know what the mechanism is for init epsg and why it
might not like being run from the the dos prompt?  I've already tried the
obvious ie putting my Proj dir in the PROJ_LIB environment variable but this
does'nt seem to make any difference.
thx for any insights,
 Paul
> ----- Original Message -----
> From: "pkishor_98" <pkishor at geoanalytics.com>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, March 18, 2003 8:48 AM
> Subject: [Mapserver-users] Re: demo package on Windows doesnt work
> > --- In mapserver-users at yahoogroups.com, "Petur Kirke"
> > <peturkirke at f...> wrote:
> > > I have installed MapServer on a Windows 2000 machine with IIS. I then
> > > installed the MapServer demo package (itasca), but I cant get it to
> > work.
> > > When I run http://itasca/demo_init.html
> > first, that is a strange URL you are trying to get to... if you are
> > accessing it through your local webserver, it should be something
like...
> > http://localhost/itasca/demo_init.html
> > > and then click on the button
> > > "Initialize", I get this error message:
> > > The page cannot be found
> > > The page you are looking for might have been removed, had its name
> > changed,
> > > or is temporarily unavailable.
> > > I dont know whats wrong. All my links seem to be ok. Can anybody
> > help me ?
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
