[Mapserver-users] Re: Flash interface to CGI MapServer
Miroslav Sodja miroslav.sodja at gov.si
Thu Mar 20 02:28:28 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0012_01C2EEBA.AF12AE40
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: 7bit
>John Hagstrand wrote:
>Thanks, Miro.  Your Flash interface looks great.  I see you are using
>the gif produced by MapServ.  Have you experimented with drawing
>map shapes within Flash?
In fact I am not using gif produced by MapServ, but JPEG produced by
MapServ and JPEG is loaded in Flash.
If you downloaded the source code you could see in MAP file attached to
zip that JPEG is produced by MapServ.
As I know, Flash cannot load gif dynamically from web, only JPEG or SWF
can be loaded.
I also found out that JPEG should be transparent and non-interlaced.
Miro Sodja
www.go2ing.com <http://www.go2ing.com/>
Content-Type: text/html;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C2EEBA.AEDBBFC0">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
 name=3D"PersonName"/>
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
  <o:DoNotOrganizeInFolder/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0cm;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";
	mso-fareast-language:EN-US;}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
p
	{mso-margin-top-alt:auto;
	margin-right:0cm;
	mso-margin-bottom-alt:auto;
	margin-left:0cm;
	font-size:12.0pt;
	mso-fareast-font-family:"Times New Roman";}
span.EmailStyle17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
@page Section1
	{size:612.0pt 792.0pt;
	margin:70.85pt 70.85pt 70.85pt 70.85pt;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
	mso-para-margin:0cm;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DSL link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal =
style=3D'mso-layout-grid-align:none;text-autospace:none'><font
size=3D2 face=3D"Courier New"><span lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:
"Courier =
New";mso-ansi-language:EN-US;mso-fareast-language:SL'>-------------------=
-----------------------------------------------------<o:p></o:p></span></=
font></p>
"Courier =
New";mso-ansi-language:EN-US;mso-fareast-language:SL'>&gt;</span></font><=
st1:PersonName><font
 "Courier New";mso-ansi-language:EN-US;mso-fareast-language:SL'>John =
Hagstrand</span></font></st1:PersonName><font
"Courier New";mso-ansi-language:EN-US;mso-fareast-language:SL'> =
wrote:<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-US;mso-fareast-language:SL'>&gt;Thanks, =
</span></font><st1:PersonName><font
 "Courier =
New";mso-ansi-language:EN-US;mso-fareast-language:SL'>Miro</span></font><=
"Courier New";mso-ansi-language:EN-US;mso-fareast-language:SL'>.<span
style=3D'mso-spacerun:yes'>&nbsp; </span>Your Flash interface looks =
great.<span
style=3D'mso-spacerun:yes'>&nbsp; </span>I see you are =
using<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-US;mso-fareast-language:SL'>&gt;the =
gif
produced by MapServ.<span style=3D'mso-spacerun:yes'>&nbsp; </span>Have =
you
experimented with drawing<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-US;mso-fareast-language:SL'>&gt;map =
shapes
within Flash?<o:p></o:p></span></font></p>
"Courier =
----------------------------------------------------<o:p></o:p></span></f=
ont></p>
"Courier =
New";mso-ansi-language:EN-US;mso-fareast-language:SL'><o:p>&nbsp;</o:p></=
span></font></p>
size=3D2 face=3DArial><span lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Arial;
mso-ansi-language:EN-US;mso-fareast-language:SL'>In fact I am not using =
gif
produced by MapServ, but JPEG produced by MapServ and JPEG is loaded in =
Flash.<o:p></o:p></span></font></p>
mso-ansi-language:EN-US;mso-fareast-language:SL'>If you downloaded the =
source
code you could see in MAP file attached to zip that JPEG is produced by
MapServ.<o:p></o:p></span></font></p>
mso-ansi-language:EN-US;mso-fareast-language:SL'><o:p>&nbsp;</o:p></span>=
</font></p>
mso-ansi-language:EN-US;mso-fareast-language:SL'>As I know, Flash cannot =
load
gif dynamically from web, only JPEG or SWF can be loaded. =
mso-ansi-language:EN-US;mso-fareast-language:SL'>I also found out that =
JPEG
should be transparent and non-interlaced.<o:p></o:p></span></font></p>
</font></p>
size=3D2 face=3D"Courier New"><span =
style=3D'font-size:10.0pt;font-family:"Courier New";
mso-fareast-language:SL'><o:p>&nbsp;</o:p></span></font></p>
style=3D'mso-layout-grid-align:none;text-autospace:none'><st1:PersonName>=
  mso-fareast-language:SL'>Miro</span></font></st1:PersonName><font =
size=3D2
 mso-fareast-language:SL'> Sodja</span></font></st1:PersonName><font =
size=3D2
mso-fareast-language:SL'><o:p></o:p></span></font></p>
mso-fareast-language:SL'><a =
href=3D"http://www.go2ing.com/">www.go2ing.com</a><o:p></o:p></span></fon=
t></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p>&nbsp;</o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0012_01C2EEBA.AF12AE40--
