[Mapserver-users] Problems getting mapserver to run w/ bitmap images
Ed McNierney ed at topozone.com
Thu Mar 20 11:00:41 EST 2003
Bernhard -
You need to set STATUS DEFAULT to make the layer turn on automatically.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: "Bernhard Rosenkränzer" [mailto:bero.rh at web.de]
Sent: Thursday, March 20, 2003 9:31 AM
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Problems getting mapserver to run w/ bitmap
images
I'm trying to set up mapserver w/ an input file in tif format (map of the local area, 1280x1024).
Even the simplest example doesn't seem to work though (the mapserver installation is ok though, the itasca
example works perfectly).
Support for bitmap formats is compiled in; mapserv -v says:
MapServer version 3.6.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=GDAL
INPUT=SHAPEFILE
This is the map file I'm using:
MAP
        NAME "TEST"
        EXTENT 0 0 1280 800
        SIZE 1280 800
        SHAPEPATH "/var/www/mapserver/data"
        IMAGECOLOR 255 255 255
        WEB
                TEMPLATE test.html
                IMAGEPATH "/var/www/mapserver/tmp/"
                IMAGEURL "/mapserver/tmp/"
        END
        LAYER
                NAME "map"
                DATA "tiled.tif"
                TYPE RASTER
                STATUS ON
        END
END
This is the launcher html:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
<html>
<head>
<title>Test</title>
<body>
<h3>Mapserver test install</h3>
<img border="1"
src="/cgi-map/mapserv?map=test.map&mode=map&map_web_imagepath=/var/www/mapserver/tmp/&map_web_imageurl=/mapserver/tmp/">
</body>
</html>
I don't get any error messages (even a mv mapserv mapserv.bin; echo 'strace -o /tmp/mapserv.trace
mapserv.bin' >mapserv; chmod +x mapserv isn't too helpful - apparently mapserv doesn't even attempt to read
the tif file), just a wrong result (1x1 png image).
Am I overlooking anything obvious?
Thanks,
Bernhard
______________________________________________________________________________
Die SMS direkt auf's Handy. - Die Blitz-SMS bei WEB.DE FreeMail
http://freemail.web.de/features/?mc=021165
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
