[Mapserver-users] Problems getting mapserver to run w/ bitmap
images
Jan Hartmann
jhart at frw.uva.nl
Thu Mar 20 11:36:50 EST 2003
Bernhard,
I'm not sure if your EXTENT matches the coordinates of the TIFF
.wld-file, but you have to set STATUS DEFAULT anyway to see somehing.
STATUS ON only shows those maps that are specifically requested in the
URL: .../mapserv?map=...&layers=...
MapServer's golden rule #1: If you don't see anything, set STATUS
DEFAULT and check your EXTENT.
Couldn't we create a separate mailing list for this problem?
Jan
Bernhard Rosenkränzer wrote:
> Hi,
> I'm trying to set up mapserver w/ an input file in tif format (map of the local area, 1280x1024).
> Even the simplest example doesn't seem to work though (the mapserver installation is ok though, the itasca
> example works perfectly).
> Support for bitmap formats is compiled in; mapserv -v says:
> MapServer version 3.6.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=GDAL
> INPUT=SHAPEFILE
> This is the map file I'm using:
> MAP
> NAME "TEST"
> EXTENT 0 0 1280 800
> SIZE 1280 800
> SHAPEPATH "/var/www/mapserver/data"
> IMAGECOLOR 255 255 255
> WEB
> TEMPLATE test.html
> IMAGEPATH "/var/www/mapserver/tmp/"
> IMAGEURL "/mapserver/tmp/"
> END
> LAYER
> NAME "map"
> DATA "tiled.tif"
> TYPE RASTER
> STATUS ON
> END
> END
> This is the launcher html:
> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
> <html>
> <head>
> <title>Test</title>
> <body>
> <h3>Mapserver test install</h3>
> <img border="1"
> src="/cgi-map/mapserv?map=test.map&mode=map&map_web_imagepath=/var/www/mapserver/tmp/&map_web_imageurl=/mapserver/tmp/">
> </body>
> </html>
> I don't get any error messages (even a mv mapserv mapserv.bin; echo 'strace -o /tmp/mapserv.trace
> mapserv.bin' >mapserv; chmod +x mapserv isn't too helpful - apparently mapserv doesn't even attempt to read
> the tif file), just a wrong result (1x1 png image).
> Am I overlooking anything obvious?
> Thanks,
> Bernhard
> ______________________________________________________________________________
> Die SMS direkt auf's Handy. - Die Blitz-SMS bei WEB.DE FreeMail
> http://freemail.web.de/features/?mc=021165
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
