[Mapserver-users] 3.7_23mar breaking where 3.6.3 ran fine ??
George Planansky george_planansky at harvard.edu
Sun Mar 23 13:13:05 EST 2003
I just moved from mapserver-3.6.3 to
mapserver_3.7_dev_2003-03-23 ... and my stuff
now fails, with and without error messages.
I've 5 closely related map file example below,
the first two just fail silently,  the second three
produce the same error message, but at different
lines.
Could someone knowledgeable have a look, and
hopefully see in a flash, what I need to change
to accommodate 3.7 ?
thanks,
George
fwiw Solaris 2.8 gcc
Only change from 3.6.3, is I added libcurl, and,
the --with-wfs --with-wfs-client options
./configure \
--disable-rxposix-conflict-error \
--with-gd \
--without-tiff \
--with-jpeg=/usr/local \
--with-zlib=/usr \
--with-png=/usr/local \
--with-freetype=/usr/local/bin/freetype-config \
--with-eppl \
--with-proj=/usr/local \
--with-gdal=/usr/local/bin/gdal-config \
--with-ogr \
--with-postgis=/usr/local/pgsql/bin/pg_config \
--with-wfs \
--with-wmsclient \
--with-wfsclient \
--enable-debug \
--with-php=/usr/local/src/php-4.3.2RC1 \
--enable-runpath >& configure.out &
mapfiles:
These both work fine with mapserver-3.6.3,
both fail silently (no image produced, no
error message) with mapserver_3.7_dev_20030323:
s23a.map
1:NAME S23a
4:EXTENT 360772.000 3757330.000 387202.000 3777160.00
5:SIZE 800 600
6:
7:SHAPEPATH "/l/www/wacke/htdocs/mapserver/cfm/data"
8:FONTSET "/l/www/wacke/htdocs/mapserver/fonts/fonts.list"
9:
10:IMAGETYPE png
11:
12:PROJECTION
13:  "init=epsg:26711" # our raster file
14:END
15:
16:LAYER # Shaded Relief Raster
17:  NAME "relief"
18:  DATA "strm_scal_utma.tif"
20:  STATUS off
21:  TYPE RASTER
22:  OFFSITE 0
23:END
24:
25:SYMBOL #Solid circle
26:  NAME 'circle'
27:  TYPE ELLIPSE
28:  POINTS 1 1 END
29:  FILLED TRUE
30:END
31:
32:LAYER
33:  NAME "faultlines"
34:  DATA "jennings"
35:  STATUS DEFAULT
36:  TYPE LINE
37:  CLASS #  class
38:    NAME "faultlines"
39:    COLOR 255 255 0
40:    SYMBOL 'circle'
41:    SIZE 4
42:  END
43:END
44:
45:LAYER
46:  NAME "faultlinesnames"
47:  DATA "jennings"
48:  STATUS DEFAULT
49:  TYPE ANNOTATION
50:  LABELITEM "NAME"
52:  CLASS # NAME's class
53:    COLOR -1 -1 -1
54:    LABEL
55:      COLOR 0 0 0
56:      MINDISTANCE 25
57:      OUTLINECOLOR 255 255 0
58:      TYPE BITMAP
59:      SIZE MEDIUM
60:      POSITION CC
61:      PARTIALS FALSE
62:      BUFFER 2
63:    END
64:  END
65:END
66:
67:LAYER # mapgrida 7.5 minute shapefile
68:  STATUS DEFAULT
69:  NAME "mapgridalines"
70:  DATA "mapgrida"
71:  PROJECTION
72:    "init=epsg:43001" # our raster file
73:  END
74:  TYPE LINE
75:  CLASS
76:    COLOR 0 0 0
77:    SYMBOL 'circle'
78:    SIZE 2
79:  END
80:END
81:
82:LAYER # mapgrida 7.5 minute shapefile quadnames
83:  STATUS DEFAULT
85:  NAME "mapgridanames"
86:  DATA "mapgrida"
87:  PROJECTION
88:    "init=epsg:43001" # our raster file
89:  END
90:  TYPE ANNOTATION
91:  LABELITEM "MAPNAME"
93:  CLASS
97:    LABEL
98:      POSITION CC
99:      COLOR 0 0 0
100:      TYPE TRUETYPE
101:      FONT arial
102:      SIZE 14
103:      ANTIALIAS TRUE
104:      PARTIALS FALSE
105:      BUFFER 2
106:    END
107:  END
108:END
109:
110:END # end of map file
111:
s32b.map
1:NAME S23
3:EXTENT 313612.000 3680020.000 477202.000 3823240.000
5:SIZE 800 600
6:
9:
10:IMAGETYPE png
11:
12:PROJECTION
14:"init=epsg:26711"
15:END
16:
17:LAYER # Shaded Relief Raster
18:  NAME "strm_scal_utma"
19:  DATA "strm_scal_utma.tif"
21:  STATUS off
22:  TYPE RASTER
23:  OFFSITE 0
24:END
25:
26:LAYER # Shaded Relief Raster
27:  NAME "scalmosaic_utm_shaded"
28:  DATA "scalmosaic_utm_shaded.tif"
29:  STATUS DEFAULT
31:  TYPE RASTER
32:  OFFSITE 0
33:END
34:
35:SYMBOL #Solid circle
36:  NAME 'circle'
37:  TYPE ELLIPSE
38:  POINTS 1 1 END
39:  FILLED TRUE
40:END
41:
42:LAYER # Jennings shapefile
43:  NAME "faultlines"
44:  DATA "jennings"
45:  STATUS DEFAULT
46:  TYPE LINE
47:  CLASS #  class
48:    NAME "faultlines"
49:    COLOR 255 255 0
50:    SYMBOL 'circle'
51:    SIZE 4
52:  END # end of faultlines class object
53:END
54:
55:LAYER # Jennings shapefile
56:  NAME "faultlines"
57:  DATA "jennings"
58:  STATUS DEFAULT
59:  TYPE ANNOTATION
60:
61:  LABELITEM "NAME"
63:  CLASS # NAME's class
65:    COLOR -1 -1 -1
66:    LABEL
67:      COLOR 0 0 0
68:      MINDISTANCE 5
71:      OUTLINECOLOR 255 255 255
75:      TYPE BITMAP
76:      SIZE MEDIUM
77:      POSITION CC
78:      PARTIALS FALSE
79:      BUFFER 2
80:    END # end of label
81:  END # end of NAMES class object
82:END # end of layer object
83:
84:LAYER # mapgrida 7.5 minute shapefile
85:  NAME "mapgrida"
86:  DATA "mapgrida"
87:  PROJECTION
89:  "init=epsg:43001"
90:  END
91:  STATUS DEFAULT
92:  TYPE LINE
95:  LABELITEM "MAPNAME"
96:  CLASS #  class
97:    NAME "mapgridalines"
98:    COLOR 0 0 0
99:    SYMBOL 'circle'
100:    SIZE 2
101:    LABEL
102:      POSITION CC
105:      COLOR 0 0 0
106:      TYPE TRUETYPE
107:      FONT arial
108:      SIZE 2
109:      ANTIALIAS TRUE
110:      PARTIALS FALSE
111:      BUFFER 2
112:    END # end of label
113:  END # end of mapgridlines class object
114:END
115:
116:END # end of map file
These two work fine with mapserver 3.6.3,
fails with error with mapserver_3.7_dev_2003-03-23:
getInteger(): Symbol definition error. (END):(51)
uses ilayers.map:
1:NAME ILAYERS
2:
7:EXTENT 360772.000 3757330.000 387202.000 3777160.00
9:SIZE 800 600
10:
11:SHAPEPATH "/l/www/wacke/htdocs/mapserver/cfm/data"
12:FONTSET "/l/www/wacke/htdocs/mapserver/fonts/fonts.list"
13:
14:IMAGETYPE png
15:
16:WEB
17:  TEMPLATE ilayers.html
18:  IMAGEPATH "/l/www/wacke/htdocs/mapserver/tmp/"
19:  IMAGEURL "/mapserver/tmp/"
20:END
21:
22:LEGEND
23:  STATUS ON
24:  LABEL
25:    TYPE TRUETYPE
26:    FONT arial
27:    COLOR 0 0 0
28:    SIZE 10
29:    ANTIALIAS TRUE
30:  END
31:END
32:
33:REFERENCE
34:  STATUS ON
35:  IMAGE "/mapserver/cfm/data/labasin_relief_small_200x150.gif"
36:  EXTENT 360772.000 3757330.000 387202.000 3777160.00
37:  SIZE  200 150
38:  COLOR -1 -1 -1
39:  OUTLINECOLOR 255 0 0
40:END
41:
42:PROJECTION
43:  "init=epsg:26711" # our raster file
44:END
45:
46:LAYER # Shaded Relief Raster
47:  NAME "relief"
48:  DATA "strm_scal_utma.tif"
49:  STATUS off
50:  TYPE RASTER
51:  OFFSITE 0
52:END
53:
62:
63:SYMBOL #Solid circle
64:  NAME 'circle'
65:  TYPE ELLIPSE
66:  POINTS 1 1 END
67:  FILLED TRUE
68:END
69:
70:LAYER
71:  NAME "faultlines"
72:  DATA "jennings"
73:  STATUS on
74:  TYPE LINE
75:  CLASS
76:    NAME "faultlines"
77:    COLOR 255 255 0
78:    SYMBOL 'circle'
79:    SIZE 3
80:  END
81:END
82:
83:LAYER
84:  NAME "faultnames"
85:  DATA "jennings"
86:  STATUS OFF
87:  TYPE ANNOTATION
88:  LABELITEM "NAME"
89:  CLASS
91:    COLOR -1 -1 -1
92:    LABEL
93:      COLOR 0 0 0
94:      MINDISTANCE 25
95:      OUTLINECOLOR 255 255 255
96:      TYPE BITMAP
97:      SIZE MEDIUM
98:      POSITION CC
99:      PARTIALS FALSE
100:      BUFFER 2
101:    END
102:  END
103:END
104:
132:
133:LAYER # mapgrida 7.5 minute shapefile
134:  STATUS ON
135:  NAME "mapgridlines"
136:  DATA "mapgrida"
137:  PROJECTION
138:    "init=epsg:43001" # our raster file
139:  END
140:  TYPE LINE
141:  CLASS
142:    NAME "Mapgrid Lines"
143:    COLOR 0 0 0
144:    SYMBOL 'circle'
145:    SIZE 2
146:  END
147:END
148:
149:LAYER # mapgrida 7.5 minute shapefile quadnames
150:  STATUS OFF
151:  NAME "mapgridnames"
152:  DATA "mapgrida"
153:  PROJECTION
154:    "init=epsg:43001" # our raster file
155:  END
156:  TYPE ANNOTATION
157:  LABELITEM "MAPNAME"
158:  CLASS
162:    LABEL
163:      POSITION CC
164:      COLOR 0 0 0
165:      TYPE TRUETYPE
166:      FONT arial
167:      SIZE 12
168:      ANTIALIAS TRUE
169:      PARTIALS FALSE
170:      BUFFER 2
171:    END
172:  END
173:END
174:
175:LAYER # co100a counties
176:  STATUS ON
177:  NAME "countylines"
178:  DATA "co100a"
179:  PROJECTION
180:    "init=epsg:43001" # our raster file
181:  END
182:  TYPE LINE
183:  CLASS
184:    NAME "County Lines"
185:    COLOR 0 0 0
186:    SYMBOL 'circle'
187:    SIZE 2
188:  END
189:END
190:
191:LAYER # co100a county names
192:  STATUS OFF
193:  NAME "countynames"
194:  DATA "co100a"
195:  PROJECTION
196:    "init=epsg:43001" # our raster file
197:  END
198:  TYPE ANNOTATION
199:  LABELITEM "NAME"
200:  CLASS
204:    LABEL
205:      POSITION CC
206:      COLOR 0 0 255
207:      TYPE TRUETYPE
208:      FONT arial
209:      SIZE 12
210:      ANTIALIAS TRUE
211:      PARTIALS FALSE
212:      BUFFER 2
213:    END
214:  END
215:END
216:
217:END # end of map file
218:
getInteger(): Symbol definition error. (END):(54)
uses izoom.map:
1:NAME IZOOM
2:
8:SIZE 400 300
9:
10:SHAPEPATH "/l/www/wacke/htdocs/mapserver/cfm/data"
11:FONTSET "/l/www/wacke/htdocs/mapserver/fonts/fonts.list"
12:
13:IMAGETYPE png
14:
15:WEB
16:  TEMPLATE izoom.html
17:  IMAGEPATH "/l/www/wacke/htdocs/mapserver/tmp/"
18:  IMAGEURL "/mapserver/tmp/"
19:END
20:
21:LEGEND
22:  STATUS ON
23:  LABEL
24:    TYPE TRUETYPE
25:    FONT arial
26:    COLOR 0 0 0
27:    SIZE 10
28:    ANTIALIAS TRUE
29:  END
30:END
31:
32:REFERENCE
34:  STATUS ON
37:  SIZE  200 150
38:  COLOR -1 -1 -1
40:END
41:
42:PROJECTION
44:"init=epsg:26711"
45:END
46:
47:LAYER # Shaded Relief Raster
48:  NAME "relief"
50:  DATA "scalmosaic_utm_shaded.tif"
51:  STATUS DEFAULT
53:  TYPE RASTER
54:  OFFSITE 0
55:END
56:
57:SYMBOL #Solid circle
58:  NAME 'circle'
59:  TYPE ELLIPSE
60:  POINTS 1 1 END
61:  FILLED TRUE
62:END
63:
64:LAYER # Jennings shapefile
65:  NAME "faultlines"
66:  DATA "jennings"
67:  STATUS DEFAULT
68:  TYPE LINE
69:  CLASS #  class
70:    NAME "faultlines"
71:    COLOR 255 255 0
72:    SYMBOL 'circle'
73:    SIZE 4
74:  END # end of faultlines class object
75:END
76:
77:LAYER # Jennings shapefile
78:  NAME "faultlines"
79:  DATA "jennings"
80:  STATUS DEFAULT
81:  TYPE ANNOTATION
82:
83:  LABELITEM "NAME"
85:  CLASS # NAME's class
87:    COLOR -1 -1 -1
88:    LABEL
89:      COLOR 0 0 0
90:      MINDISTANCE 5
93:      OUTLINECOLOR 255 255 255
97:      TYPE BITMAP
98:      SIZE MEDIUM
99:      POSITION CC
100:      PARTIALS FALSE
101:      BUFFER 2
102:    END # end of label
103:  END # end of NAMES class object
104:END # end of layer object
105:
106:LAYER # mapgrida 7.5 minute shapefile
107:  NAME "mapgrida"
108:  DATA "mapgrida"
109:  PROJECTION
111:  "init=epsg:43001"
112:  END
113:  STATUS DEFAULT
114:  TYPE LINE
117:  LABELITEM "MAPNAME"
118:  CLASS #  class
119:    NAME "mapgridalines"
120:    COLOR 0 0 0
121:    SYMBOL 'circle'
122:    SIZE 2
123:    LABEL
124:      POSITION CC
127:      COLOR 0 0 0
128:      TYPE TRUETYPE
129:      FONT arial
130:      SIZE 2
131:      ANTIALIAS TRUE
132:      PARTIALS FALSE
133:      BUFFER 2
134:    END # end of label
135:  END # end of mapgridlines class object
136:END
137:
138:END # end of map file
139:
140:END # end of map file
141:
getInteger(): Symbol definition error. (END):(98)
uses iquery.map:
1:NAME IQUERY
2:STATUS ON
3:
7:
10:
17:EXTENT  449985.000 3849975.000 650025.000 4050015.000
18:SIZE 800 600
19:UNITS METERS
20:SHAPEPATH "/l/www/wacke/htdocs/mapserver/cfm/data"
21:FONTSET "/l/www/wacke/htdocs/mapserver/fonts/fonts.list"
22:
24:IMAGETYPE gif
26:
27:PROJECTION
28:  "init=epsg:26711" # our raster file
29:END
30:
31:WEB
32:  HEADER iquery_header.html
33:  TEMPLATE iquery.html
34:  FOOTER iquery_footer.html
37:  IMAGEPATH "/l/www/wacke/htdocs/mapserver/tmp/"
38:  IMAGEURL "/mapserver/tmp/"
39:  METADATA
40:  END
41:END
42:
43:QUERYMAP
44:  SIZE 400 300
45:  STATUS ON
46:  STYLE HILITE
47:  COLOR 255 0 0
48:END
49:
50:REFERENCE
51:  STATUS ON
52:  IMAGE "/mapserver/cfm/data/labasin_relief_small_200x150.gif"
53:  EXTENT 360772.000 3757330.000 387202.000 3777160.00
54:  SIZE  200 150
55:  COLOR -1 -1 -1
56:  OUTLINECOLOR 255 0 0
57:END
58:
59:LEGEND
60:  STATUS ON
61:  LABEL
62:    TYPE TRUETYPE
63:    FONT arial
64:    COLOR 0 0 0
65:    SIZE 10
66:    ANTIALIAS TRUE
67:  END
68:END
69:
70:SCALEBAR
71:  IMAGECOLOR 255 255 255
72:  LABEL
73:    COLOR 255 255 255
74:    SIZE tiny
75:  END
76:  STYLE 1
77:  SIZE 80 2
78:  COLOR 255 255 255
79:  UNITS MILES
80:  INTERVALS 1
81:  TRANSPARENT TRUE
82:  STATUS TRUE
83:END
84:
85:SYMBOL
86:  NAME 'circle'
87:  TYPE ELLIPSE
88:  POINTS 1 1 END
89:  FILLED TRUE
90:END
91:
92:LAYER # Shaded Relief Raster
93:  NAME "relief"
95:  DATA "sca_0001.tif"         # tile of new Shaded Relief Raster
96:  STATUS off
97:  TYPE RASTER
98:  OFFSITE 0
99:END
100:
101:LAYER
102:  NAME "faults"
103:  DATA "jennings"
104:  TYPE LINE
105:  STATUS on
106:
107:  CLASS
108:    NAME "Faults"
109:    TEMPLATE "faults.html"
110:    COLOR 255 255 0
111:    SYMBOL 'circle'
112:    SIZE 3
113:  END
114:
115:  HEADER "faults_header.html"
116:  FOOTER "faults_footer.html"
117:
118:  TOLERANCE 3
119:END
120:
121:LAYER
122:  NAME "faultnames"
123:  DATA "jennings"
124:  STATUS OFF
125:  TYPE ANNOTATION
126:  LABELITEM "NAME"
127:  CLASS
129:    COLOR -1 -1 -1
130:    LABEL
131:      COLOR 0 0 0
132:      MINDISTANCE 25
133:      OUTLINECOLOR 255 255 255
134:      TYPE BITMAP
135:      SIZE MEDIUM
136:      POSITION CC
137:      PARTIALS FALSE
138:      BUFFER 2
139:    END
140:  END
141:END
142:
143:LAYER # mapgrida 7.5 minute shapefile
144:  STATUS ON
145:  NAME "mapgrid"
146:  DATA "mapgrida"
147:  PROJECTION
148:    "init=epsg:43001" # our raster file
149:  END
150:  TYPE LINE
151:  CLASS
152:    NAME "Mapgrid"
153:    COLOR 0 0 0
154:    SYMBOL 'circle'
155:    SIZE 2
156:  END
157:END
158:
159:LAYER # mapgrida 7.5 minute shapefile quadnames
160:  STATUS OFF
161:  NAME "mapgridnames"
162:  DATA "mapgrida"
163:  PROJECTION
164:    "init=epsg:43001" # our raster file
165:  END
166:  TYPE ANNOTATION
167:  LABELITEM "MAPNAME"
168:  CLASS
172:    LABEL
173:      POSITION CC
174:      COLOR 0 0 0
175:      TYPE TRUETYPE
176:      FONT arial
177:      SIZE 12
178:      ANTIALIAS TRUE
179:      PARTIALS FALSE
180:      BUFFER 2
181:    END
182:  END
183:END
184:
185:LAYER # co100a county
186:  STATUS ON
187:  NAME "county"
188:  DATA "co100a"
189:  PROJECTION
190:    "init=epsg:43001" # our raster file
191:  END
192:  TYPE LINE
193:  CLASS
194:    NAME "Counties"
195:    TEMPLATE "county.html"
196:    COLOR 0 0 0
197:    SYMBOL 'circle'
198:    SIZE 2
199:  END
200:
201:  HEADER "county_header.html"
202:  FOOTER "county_footer.html"
203:
204:  TOLERANCE 3
205:END
206:
207:LAYER # co100a county names
208:  STATUS OFF
209:  NAME "countynames"
210:  DATA "co100a"
211:  PROJECTION
212:    "init=epsg:43001" # our raster file
213:  END
214:  TYPE ANNOTATION
215:  LABELITEM "NAME"
216:  CLASS
220:    LABEL
221:      POSITION CC
222:      COLOR 0 0 255
223:      TYPE TRUETYPE
224:      FONT arial
225:      SIZE 12
226:      ANTIALIAS TRUE
227:      PARTIALS FALSE
228:      BUFFER 2
229:    END
230:  END
231:END
232:
233:END # end of map file
234:
