[Mapserver-users] Dynamic Layers with MapScript
Björn Platzen bplatzen at sosnetz.de
Tue Mar 25 17:01:22 EST 2003
Hello list,
I have made things with the MapServer CGI, but I'm a Greenhorn in
Mapscript...
Is it possible to generate polygons or lines dynamically with MapScript?
I'm going to use Python-MapScript.
At the moment I just need an answer if it is possible in principal,
because I'm going to have a negotiation with a customer in about 10
hours...
The job will be to show road construction on a map. We have shp's for
the streets and I think we will get coordinates for the
construction-areas and duration of the construction from a
MySQL-database. The construction-areas should be laid upon the map only
during the construction-time, so that the customer's job will be to put
the data into the DB and nothing more.
I would be very glad to get an answer before I talk to my customer...
Thanks in advance,
Bjoern.
small office solutions
info at sosnetz.de  -  http://www.sosnetz.de
