[Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki page
Antti.Roppola at brs.gov.au Antti.Roppola at brs.gov.au
Wed Mar 26 01:00:33 EST 2003
Daryl Herzmann wrote:
>>3.  The header for the XML document seems to work fine.  I tried adding echo
>>"<h1>hello world</h1>"; then viewing the document in a web browser.  The
>>result is Hello World, then the expected error message similar to:
>>Warning: Cannot add header information - headers already sent by (output
>>started at http://localhost/fawkner_mapserv/wms.php:2) in
>>http://localhost/fawkner_mapserv/wms.php on line 3
>This is a problem.  Are you certain that your php header() call is the
>first thing that is in your .php file?   If you have an empty line, then
>that will constitute output and you can't resend headers...
To clarify, I suggested (temporarily) adding an echo to make sure
that the web server and PHP are configured correctly. AFAIK, it was.
Apologies if this confused anyone.
Cheers,
Antti
