[Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki page
Thomas Bartlett tbartlett at dddd.com.au
Wed Mar 26 16:36:20 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0034_01C2F43B.F1C766A0
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Hello All,
Please find attached a copy of my map file and the resulting GetCapabilities
XML document!
I spent 6 hrs on it last night changing things in the map file as well as
reinstalling ArcExplorer and the Extension but it is doesn't seem to work.
Cheers Tom
----- Original Message -----
To: <tbartlett at dddd.com.au>; <akrherz at iastate.edu>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, March 26, 2003 5:11 PM
Subject: RE: [Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki
page
> Thomas Bartlett wrote:
> > However  GetCapabilities does not check whether the map file is WMS
> > compliant does it !  It simply checks that the map file is correct as
far as
> > MapServer is concerned !!  I remove all reference to WMS from the same
map
> > file and the GetCapabilities XML document returned contain NO warning.
This
> > map file is obviously not WMS compliant (as it contains none of the WMS
> > tags) hence my conclusion.  Am I wrong in this conclusion ??
> That seems like a reasonable conclusion to me, and suggests that a good
> next step would be to check the map and layers to make sure that no
> mandatory WMS items have been omitted. It would certainly explain why
> Arc Explorer doesn't like the output you are sending.
> BTW, thanks for the insight into what is and is not checked, lets me
> cross one more item off my list of "things to investigate". :o)
> Cheers,
> Antti
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/octet-stream;
	name="wms.php"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
	filename="wms.php"
<?php header("Content-type:application/vnd.ogc.gml"); ?>
<WMT_MS_Capabilities version=3D"1.1.1" updateSequence=3D"0">
<Service> <!-- a service IS a MapServer mapfile -->
  <Name>GetMap</Name> <!-- WMT defined -->
  <Title>Fawkner MapServer</Title>
  <Abstract>Because I have nothing better to do</Abstract>
  <OnlineResource xmlns:xlink=3D"http://www.w3.org/1999/xlink" =
xlink:href=3D"http://localhost/_cgi-bin/mapserv.exe?map=3Dc:\inetpub\wwwr=
oot\fawkner_mapserv\fawkner_wms.map&"/>
  <ContactInformation>
  </ContactInformation>
  <AccessConstraints>none</AccessConstraints>
</Service>
<Capability>
  <Request>
    <GetCapabilities>
      <Format>application/vnd.ogc.wms_xml</Format>
      <DCPType>
        <HTTP>
          <Get><OnlineResource =
oot\fawkner_mapserv\fawkner_wms.map&"/></Get>
          <Post><OnlineResource =
oot\fawkner_mapserv\fawkner_wms.map&"/></Post>
        </HTTP>
      </DCPType>
    </GetCapabilities>
    <GetMap>
      <Format>image/gif</Format>
      <Format>image/png</Format>
      <Format>image/jpeg</Format>
      <Format>image/wbmp</Format>
      <DCPType>
        <HTTP>
        </HTTP>
      </DCPType>
    </GetMap>
    <GetFeatureInfo>
      <Format>text/plain</Format>
      <Format>text/html</Format>
      <Format>application/vnd.ogc.gml</Format>
      <DCPType>
        <HTTP>
        </HTTP>
      </DCPType>
    </GetFeatureInfo>
  </Request>
  <Exception>
    <Format>application/vnd.ogc.se_xml</Format>
    <Format>application/vnd.ogc.se_inimage</Format>
    <Format>application/vnd.ogc.se_blank</Format>
  </Exception>
  <VendorSpecificCapabilities />
  <Layer>
    <Name>FAWKNER</Name>
    <SRS>EPSG:4326</SRS>
    <LatLonBoundingBox minx=3D"112.286" miny=3D"-45.0502" =
maxx=3D"154.857" maxy=3D"-8.52123" />
    <BoundingBox SRS=3D"EPSG:4326"
                minx=3D"112.286" miny=3D"-45.0502" maxx=3D"154.857" =
    <ScaleHint min=3D"0.498903" max=3D"498903" />
    <Layer queryable=3D"0" opaque=3D"0" cascaded=3D"0">
        <Name>oceansea</Name>
        <Title>CountyoceanseaBoundary</Title>
        <Abstract>Oceans and Seas</Abstract>
        <LatLonBoundingBox minx=3D"72" miny=3D"-55.9612" =
maxx=3D"170.731" maxy=3D"-2.10025" />
                    minx=3D"72" miny=3D"-55.9612" maxx=3D"170.731" =
    </Layer>
  </Layer>
</Capability>
</WMT_MS_Capabilities>
	name="fawkner_wms.map"
	filename="fawkner_wms.map"
NAME FAWKNER=0A=
STATUS ON=0A=
SIZE 620 500=0A=
EXTENT 112.285715 -45.050205 154.857144 -8.521226=0A=
UNITS DD=0A=
SHAPEPATH "data"=0A=
#FONTSET "fonts/fonts.list"=0A=
IMAGECOLOR -1 -1 -1=0A=
=0A=
IMAGETYPE PNG=0A=
=0A=
PROJECTION=0A=
  "init=3Depsg:4326"=0A=
END=0A=
=0A=
WEB=0A=
  TEMPLATE fawkner.html=0A=
  MINSCALE 1000=0A=
  MAXSCALE 1000000000=0A=
  IMAGEPATH "set in fawkner_init.html"=0A=
  IMAGEURL "set in fawkner_init.html"=0A=
  METADATA=0A=
    WMS_TITLE "Fawkner MapServer"=0A=
    WMS_ABSTRACT "Because I have nothing better to do"=0A=
    WMS_ACCESSCONSTRAINTS none=0A=
    WMS_ONLINERESOURCE =
"http://localhost/_cgi-bin/mapserv?map=3Dc:\inetpub\wwwroot\fawkner_mapse=
rv\fawkner_wms.map&"=0A=
    WMS_SRS "EPSG:4326"=0A=
  END=0A=
END=0A=
=0A=
LAYER=0A=
  NAME "oceansea"=0A=
  TYPE POLYGON=0A=
  DATA oceansea=0A=
  STATUS ON=0A=
  CLASS=0A=
    NAME 'Ocean / Sea'=0A=
    SIZE 0=0A=
    COLOR 35 193 245=0A=
  END=0A=
  METADATA=0A=
    WMS_TITLE "CountyoceanseaBoundary"=0A=
    WMS_ABSTRACT "Oceans and Seas"=0A=
  END=0A=
END=0A=
=0A=
END
------=_NextPart_000_0034_01C2F43B.F1C766A0--
