[Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki page
Antti.Roppola at brs.gov.au Antti.Roppola at brs.gov.au
Wed Mar 26 18:53:34 EST 2003
Hi Thomas,
I have looked at your map file and PHP, you need to replace
every instance of '&' with '&' in both files. As I discovered
myself, the semi-colon is easy to overlook but very important.
Cheers,
Antti
-----Original Message-----
From: Thomas Bartlett [mailto:tbartlett at dddd.com.au]
Sent: Thursday, 27 March 2003 8:50 AM
To: Daryl Herzmann
Cc: Antti.Roppola at brs.gov.au; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS -
Wiki page
I know that I have tried using "&amp" at the end of the WMS_ONLINERESOURCE
tab in the map file but it didn't seem to help.  Is this the only place I
should need it ?
Either way I'm adding it the list of thing to try !
Cheers
----- Original Message -----
To: "Thomas Bartlett" <tbartlett at dddd.com.au>
Cc: <Antti.Roppola at brs.gov.au>; <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, March 27, 2003 8:43 AM
Subject: Re: [Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki
page
> Hi,
> Are you using "&amp;" in your document and not plain "&" ? :)
> Daryl
> On Thu, 27 Mar 2003, Thomas Bartlett wrote:
> >Hello All,
> >Please find attached a copy of my map file and the resulting
GetCapabilities
> >XML document!
> >I spent 6 hrs on it last night changing things in the map file as well as
> >reinstalling ArcExplorer and the Extension but it is doesn't seem to
work.
> >Cheers Tom
> >From: <Antti.Roppola at brs.gov.au>
> >To: <tbartlett at dddd.com.au>; <akrherz at iastate.edu>
> >Cc: <mapserver-users at lists.gis.umn.edu>
> >Sent: Wednesday, March 26, 2003 5:11 PM
> >Subject: RE: [Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki
> >page
> >> > However  GetCapabilities does not check whether the map file is WMS
> >> > compliant does it !  It simply checks that the map file is correct as
> >far as
> >> > MapServer is concerned !!  I remove all reference to WMS from the
same
> >map
> >> > file and the GetCapabilities XML document returned contain NO
warning.
> >This
> >> > map file is obviously not WMS compliant (as it contains none of the
WMS
> >> > tags) hence my conclusion.  Am I wrong in this conclusion ??
> >> That seems like a reasonable conclusion to me, and suggests that a good
> >> next step would be to check the map and layers to make sure that no
> >> mandatory WMS items have been omitted. It would certainly explain why
> >> Arc Explorer doesn't like the output you are sending.
> >> BTW, thanks for the insight into what is and is not checked, lets me
> >> cross one more item off my list of "things to investigate". :o)
> >> Cheers,
> >> Antti
> >> _______________________________________________
> >> Mapserver-users mailing list
> >> Mapserver-users at lists.gis.umn.edu
> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>  * Daryl Herzmann (akrherz at iastate.edu)
>  * Program Assistant -- Iowa Environmental Mesonet
>  * http://mesonet.agron.iastate.edu
