[Mapserver-users] Expression parser error
Jan Hartmann jhart at frw.uva.nl
Thu Mar 27 11:28:24 EST 2003
Right! Thanks Daniel for pointing it out. It has to be without quotes
and with matching parentheses:
EXPRESSION ([GEO] < 120)
Puneet's solution should work too:
(([GEO]) < 120),
Jan
Daniel Morissette wrote:
> Jan Hartmann wrote:
>>You have to put the EXPRESSION between quotes, whenever it contains spaces.
>>EXPRESSION  "([GEO]) < 120)"
>>Generally it is safer to put everything after a keyword between quotes.
> Actually, using quotes is safer for everything except expressions.
> Unless I'm mistaken, putting an expression between quotes like this
> results in a constant expression, so the logical expression would never
> be evaluated.  The problem here is what Puneet reported in another
> email: a missing parenthesis.
