[Mapserver-users] (no subject)
mapserv at dinequest.us
Fri Mar 28 11:04:07 EST 2003
Quoting Lowell Filak <lfilak at medinaco.org>:
> I think the original suggestion was to make sure the IMAGEPATH (which is
> where the temporary image files, ie. maps, are created) points to somewhere
> in httpdocs instead of cgi-bin and then make sure the permissions on the temp
> directory are 777.
> The data directory can stay in cgi-bin so your data is not directly
> downloadable.
> Lowell F.
I have it set up in this manner:
-my demo.map file is in the cgi-bin
-my data directory in in httpdocs (but i will change it to /cgi-bin/data, as
you've suggested, once i get the mapserver working).
-my IMAGEPATH to my data directory
here is my url i put into the browser to test it:
http://www.dinequest.us/cgi-bin/mapserv?map=/cgi-
bin/demo.map&VERSION=1.1.0&REQUEST=GetMap&BBOX=-83.81,41.25,-81.80,42.79
also have tried:
map=demo.map&VERSION=1.1.0&REQUEST=GetMap&BBOX=-83.81,41.25,-81.80,42.79
here is my updated map file:
NAME DEMO
WEB
IMAGEPATH "/usr/local/psa/home/vhosts/dinequest.us/httpdocs/data/"
IMAGEURL "http://localhost/data/"
END
UNITS DD
EXTENT -178 16 -66 74
SIZE 324 210
SHAPEPATH "/usr/local/psa/home/vhosts/dinequest.us/httpdocs/data/"
LAYER
NAME "states"
DATA dtl_st.shp
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 250 247 222
END # end of class object
END # end of layer object
IMAGETYPE JPEG
IMAGEQUALITY 90
INTERLACE OFF
END # end of map file
> The following message was sent by mapserv at dinequest.us on Fri, 28 Mar 2003
> 00:05:57 -0500.
> > thanks for responding, Steve,
> > - I've tried what you've said with the trailing slash (in the mapfile)- i
> still
> > recieved a "premature end of script headers" error.
> > - I've moved the data folder into my httpdocs folder and adjusted my map
> file to
> > point there instead- same result.
> > - reset permissions on my cgi-bin, shp files, map file and shp file "data"
> dir
> > to chmod 7777- same result.
> > - I re-uploaded mapserv (static library file 2.5 megs) in ASCII mode, just
> to
> > make sure i actually did send it ascii and not binary- same result.
> > - I installed apache on my redhat 2.4.18-3 box and set up the same mapserv
> file
> > on the localhost- works fine.
> > I'm stumped... I'm begining to think that i have to start editing the code
> to
> > produce a proper header?
> > Quoting Steve Lime <steve.lime at dnr.state.mn.us>:
> > > The setting for IMAGEPATH looks suspect. The way it's set mapserv will
> > > be looking for a writable
> > > directory in your cgi-bin directory. That's probably not what you want.
> > > That parameter should
> > > be full path and should have a trailing slash.
> > > Steve
> > > >>> <mapserv at dinequest.us> 03/27/03 12:34PM >>>
> > > hello everyone,
> > > I'm hoping someone can help me by suggesting some options in hopes that
> > > i can
> > > get mapserv working on my server. I layed out my steps so that it can
> > > be easier
> > > to follow:
> > > - I have a redhat linux box (2.4.18-3 i386) which i've built a static
> > > library
> > > mapserv on. (ran mapserv -v and it listed correct supports)
> > > - I uploaded it to my server's cgi-bin (which is a redhat 2.4.19 i386)
> > > - set chmod 755 on mapserv
> > > - set up demo.map mapfile correctly in the cgi-bin
> > > - uploaded proper data in cgi-bin under the "data" directory
> > > - ran from browser: http://<my location>/cgi-bin/mapserv?
> > > *recieved internal error ("premature end of script headers" in log)
> > > - renamed mapserv to mapserv.cgi
> > > i assume that this is not a mapfile issue, but here is my mapfile
> > > anyway:
> > > NAME DEMO
> > > WEB
> > > IMAGEPATH "data"
> > > IMAGEURL "http://www.dinequest.us/data"
> > > END
> > > END
> > > UNITS DD
> > > SIZE 324 210
> > > SHAPEPATH "data"
> > > LAYER
> > > NAME "states"
> > > DATA dtl_st
> > > STATUS DEFAULT
> > > TYPE POLYGON
> > > CLASS
> > > COLOR 250 247 222
> > > IMAGETYPE JPEG
> > > IMAGEQUALITY 90
> > > INTERLACE OFF
> > > I appreciate any other suggestions. You guys are the gurus and i would
> > > be alot
> > > farther behind if it weren't for you all. Thanks in advance -bp
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
