[Mapserver-users] (no subject)
mapserv at dinequest.us
Fri Mar 28 13:39:33 EST 2003
still no luck with the "../httpdocs/data/".
perhaps my ISP may have a strange permission setting in apache or some other
apache CGI issue that i'm unaware of because it works on my box i have set up
with the same mapserv static binary, using the same mapfile (different dirs of
course), under the same version of apache (1.3.27).
or it might be to do with the url string? Does mapserver know to send the image
back to the url source? That seems like a big "Duh", but there is obviously
something i'm missing that's causing the "premature end of script headers"
error, and i'm pretty sure it doesn't have to do with the map file...
Quoting Lowell Filak <lfilak at medinaco.org>:
> If you change IMAGEPATH to "../httpdocs/data/" does it help?
> Lowell F.
> The following message was sent by mapserv at dinequest.us on Fri, 28 Mar 2003
> 11:04:07 -0500.
> > > I think the original suggestion was to make sure the IMAGEPATH (which is
> > > where the temporary image files, ie. maps, are created) points to
> somewhere
> > > in httpdocs instead of cgi-bin and then make sure the permissions on the
> temp
> > > directory are 777.
> > > The data directory can stay in cgi-bin so your data is not directly
> > > downloadable.
> > > Lowell F.
> > I have it set up in this manner:
> > -my demo.map file is in the cgi-bin
> > -my data directory in in httpdocs (but i will change it to /cgi-bin/data,
> as
> > you've suggested, once i get the mapserver working).
> > -my IMAGEPATH to my data directory
> > here is my url i put into the browser to test it:
> > http://www.dinequest.us/cgi-bin/mapserv?map=/cgi-
> > bin/demo.map&VERSION=1.1.0&REQUEST=GetMap&BBOX=-83.81,41.25,-81.80,42.79
> > also have tried:
> > map=demo.map&VERSION=1.1.0&REQUEST=GetMap&BBOX=-83.81,41.25,-81.80,42.79
> > here is my updated map file:
> > NAME DEMO
> > WEB
> > IMAGEPATH "/usr/local/psa/home/vhosts/dinequest.us/httpdocs/data/"
> > IMAGEURL "http://localhost/data/"
> > END
> > UNITS DD
> > EXTENT -178 16 -66 74
> > SIZE 324 210
> > SHAPEPATH "/usr/local/psa/home/vhosts/dinequest.us/httpdocs/data/"
> > LAYER
> > NAME "states"
> > DATA dtl_st.shp
> > STATUS DEFAULT
> > TYPE POLYGON
> > CLASS
> > COLOR 250 247 222
> > END # end of class object
> > END # end of layer object
> > IMAGETYPE JPEG
> > IMAGEQUALITY 90
> > INTERLACE OFF
> > END # end of map file
> 2003
> > > 00:05:57 -0500.
> > > > thanks for responding, Steve,
> > > > - I've tried what you've said with the trailing slash (in the mapfile)-
> i
> > > still
> > > > recieved a "premature end of script headers" error.
> > > > - I've moved the data folder into my httpdocs folder and adjusted my
> map
> > > file to
> > > > point there instead- same result.
> > > > - reset permissions on my cgi-bin, shp files, map file and shp file
> "data"
> > > dir
> > > > to chmod 7777- same result.
> > > > - I re-uploaded mapserv (static library file 2.5 megs) in ASCII mode,
> just
> > > to
> > > > make sure i actually did send it ascii and not binary- same result.
> > > > - I installed apache on my redhat 2.4.18-3 box and set up the same
> mapserv
> > > file
> > > > on the localhost- works fine.
> > > > I'm stumped... I'm begining to think that i have to start editing the
> code
> > > to
> > > > produce a proper header?
> > > > Quoting Steve Lime <steve.lime at dnr.state.mn.us>:
> > > > > The setting for IMAGEPATH looks suspect. The way it's set mapserv
> will
> > > > > be looking for a writable
> > > > > directory in your cgi-bin directory. That's probably not what you
> want.
> > > > > That parameter should
> > > > > be full path and should have a trailing slash.
> > > > > Steve
> > > > > >>> <mapserv at dinequest.us> 03/27/03 12:34PM >>>
> > > > > hello everyone,
> > > > > I'm hoping someone can help me by suggesting some options in hopes
> that
> > > > > i can
> > > > > get mapserv working on my server. I layed out my steps so that it
> can
> > > > > be easier
> > > > > to follow:
> > > > > - I have a redhat linux box (2.4.18-3 i386) which i've built a
> static
> > > > > library
> > > > > mapserv on. (ran mapserv -v and it listed correct supports)
> > > > > - I uploaded it to my server's cgi-bin (which is a redhat 2.4.19
> i386)
> > > > > - set chmod 755 on mapserv
> > > > > - set up demo.map mapfile correctly in the cgi-bin
> > > > > - uploaded proper data in cgi-bin under the "data" directory
> > > > > - ran from browser: http://<my location>/cgi-bin/mapserv?
> > > > > *recieved internal error ("premature end of script headers" in log)
> > > > > - renamed mapserv to mapserv.cgi
> > > > > i assume that this is not a mapfile issue, but here is my mapfile
> > > > > anyway:
> > > > > NAME DEMO
> > > > > WEB
> > > > > IMAGEPATH "data"
> > > > > IMAGEURL "http://www.dinequest.us/data"
> > > > > END
> > > > > END
> > > > > UNITS DD
> > > > > SIZE 324 210
> > > > > SHAPEPATH "data"
> > > > > LAYER
> > > > > NAME "states"
> > > > > DATA dtl_st
> > > > > STATUS DEFAULT
> > > > > TYPE POLYGON
> > > > > CLASS
> > > > > COLOR 250 247 222
> > > > > IMAGETYPE JPEG
> > > > > IMAGEQUALITY 90
> > > > > INTERLACE OFF
> > > > > I appreciate any other suggestions. You guys are the gurus and i
> would
> > > > > be alot
> > > > > farther behind if it weren't for you all. Thanks in advance -bp
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> > > > > Mapserver-users at lists.gis.umn.edu
> > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
