[Mapserver-users] Multiple mapserver compilation on the same computer
Antti.Roppola at brs.gov.au Antti.Roppola at brs.gov.au
Mon Mar 31 18:35:14 EST 2003
I have several 3.7 versions I am playing with.
php_mapscript.so is a symlink to my current default version
(say php_mapscript.3.6.4.so) and then I have others like
"php_mapscript.3.7.030127.so" which I can use by name:
	dl("php_mapscript.3.7.030127.so");
Basicially compile as per normal then rename the .so. Just remember
to keep notes on you configure options in case you want to replicate
a build. :o)
Antti
-----Original Message-----
Sent: Tuesday, 1 April 2003 2:18 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Multiple mapserver compilation on the same computer
Hello everybody,
i would like to get a multiple compilation of mapserver on the same computer. That's to say for example
- a compil maserver_classic for typical use.
- a compil ECW for special application.
I suppose i have to make some changes before compiling and then to call the correct php_mapscriptxxx.so?
Any idea?
thanks a lot,
fx gamoy
