[Mapserver-users] Postgis "explain verbose"-Error [carl.anderson@vadose.org]
Carl Anderson carl.anderson at vadose.org
Tue May 13 01:12:22 EDT 2003
--tThc/1wpZn/ma/RB
Content-Type: text/plain; format=flowed; charset=ISO-8859-1
Content-Disposition: inline
Content-Transfer-Encoding: 8bit
On 2003.05.13 01:00 Carl Anderson wrote:
On 2003.05.12 09:44 Christina Biakowski (CCGIS) wrote:
> Querying a Postgis-Layer (by clicking in the map) I get the
> following error-message:
> "msPOSTGISLayerGetShape(): Query error. Error executing POSTGIS SQL
> statement (in FETCH ALL): EXPLAIN VERBOSE SELECT * FROM staedte -
> Error with
christina and steff
PostgreSQL 7.3 changed the way in which EXPLAIN returns information.
The attached patch for mappostgis.c adds support for the 7.3.x style.
apply to CVS with
    patch < mapserver-pg7.3.patch
and recompile
Note that if you have postgis tables with conflicting names in
different schemas you should think about running the find_srid patch as
well.
Note that both of these have been previously sent to the postgis list.
While both of these have been in use in my org for a month or more YMMV
so be careful.  These are not the alpha patch previously mentioned.
C.
--- mappostgis.c	Tue May 13 00:51:41 2003
+++ mappostgis_hack.c	Tue May 13 00:52:59 2003
@@ -1314,13 +1305,16 @@
  	msPOSTGISLayerParseData(layer->data, geom_column_name,
table_name, urid_name, user_srid);
+       query_result = PQexec(layerinfo->conn, "set explain_pretty_print
= on");
+// in pre 7.3 databases this will fail without problems so relax
  	// two cases here.  One, its a table (use select * from table)
otherwise, just use the select clause
  	sprintf(sql,"EXPLAIN VERBOSE SELECT * FROM %s",table_name);
  		// this will call the postresql_NOTICE_HANDLER()
callback!  layer->fields will be populated
  	query_result = PQexec(layerinfo->conn, sql );
-    if (!(query_result) || PQresultStatus(query_result) !=
PGRES_COMMAND_OK)
+    if (!(query_result) || (PQresultStatus(query_result) !=
PGRES_COMMAND_OK && PQresultStatus(query_result) != PGRES_TUPLES_OK ))
  		char tmp[4000];
@@ -1335,6 +1329,44 @@
  	  	query_result = NULL;
  		return(MS_FAILURE);
+   if (PQresultStatus(query_result) == PGRES_TUPLES_OK )
+     //build layerinfo->fields from tuples passed back
+     int	rows,row;
+     char	*result;
+     char	*tup;
+     char	*str,*str2;
+     if (  layerinfo->fields )
+       free(layerinfo->fields);     // free up space
+     result = malloc ( 6000) ;
+     layerinfo->fields = result;
+     result[0] = 0; //null terminate it
+     rows = PQntuples(query_result);
+     for ( row=0; row < rows; row++ )
+       tup = PQgetvalue(query_result,row,0);
+       str = strstr(tup,":resname ");
+       if ( str )
+       if ( str )
+         str += 9;
+         str2 = strstr(str," ");
+         if  (strncmp(str, "<>", (str2-str)))
+           if ( strlen(result) > 0 )
+             strcat(result,",");
+		strncat(result,str,(str2-str));
  	//layerinfo->fields is a string with a list of all the columns
  		// # of items is number of "," in string + 1
--tThc/1wpZn/ma/RB
Content-Type: text/plain; charset=us-ascii
Content-Disposition: attachment; filename="mapserver-pg7.3.patch"
 	msPOSTGISLayerParseData(layer->data, geom_column_name, table_name, urid_name, user_srid);
+       query_result = PQexec(layerinfo->conn, "set explain_pretty_print = on");
 	// two cases here.  One, its a table (use select * from table) otherwise, just use the select clause
 		// this will call the postresql_NOTICE_HANDLER() callback!  layer->fields will be populated
-    if (!(query_result) || PQresultStatus(query_result) != PGRES_COMMAND_OK)
+    if (!(query_result) || (PQresultStatus(query_result) != PGRES_COMMAND_OK && PQresultStatus(query_result) != PGRES_TUPLES_OK ))
 		char tmp[4000];
 		return(MS_FAILURE);
+     int	rows,row;
+     char	*result;
+     char	*tup;
+     char	*str,*str2;
+       if ( str )
+       if ( str )
+         str += 9;
--tThc/1wpZn/ma/RB
Content-Type: message/rfc822; charset=us-ascii
Date: Mon, 17 Mar 2003 20:25:22 -0500
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Subject: find_srid() change request
Message-ID: <20030318012522.GA10435 at vadose.dvg>
Mime-Version: 1.0
X-Mailer: Balsa 2.0.9
Status: RO
To allow support for schema enabled Postgis in Mapserver 6.3
I request that find_srid () be changed in the following way.
This is clearly a hack but will extend the use of PostGIS w/ schemas
into Mapserver 3.6.x
preserve existing behaviour
extend behavior to automatically promote a namespace.table reference
into a schema in the place of parameter 1
into a table in place of parameter 2
Mapserver 3.6.x  converts
         CONNECTIONTYPE postgis
         DATA 'shape from cities.annex_cases'
into a Binary Cursor containing
  .. find_srid('','cities.annex_cases','shape') ...
We have geotables in schemas to provide a level of sanity and
context to the geotables;
Postgresql 7.3 by default will search the users named schema and then
the public schema.  This is an unacceptable exposure of the schema owner
to web traffic.  We prefer to use extremely limited accounts for
mapserver.  So when the Pg user is different from the schema the tables
are in the tables are not found.  The propsed style will allow a user
to explicitly specify the schema.
the the above example the public.geometry_columns table contains
  f_table_catalog | f_table_schema |  f_table_name  | f_geometry_column
| coord_dimension | srid |     type     |
                  | cities         | annex_cases    | shape
        2 |   -1 | MULTIPOLYGON
proposed new  find_srid()
-- FIND_SRID( <schema/database>, <table>, <geom col> )
CREATE FUNCTION find_srid(varchar,varchar,varchar) RETURNS int4 AS
'DECLARE
   schem text;
   tabl text;
   sr int4;
BEGIN
   schem = $1;
   tabl = $2;
-- if the table contains a . and the schema is empty
-- split the table into a schema and a table
-- otherwise drop through to default behavior
   if ( schem = '''' and tabl ~ ''\.'' ) then
     schem = substr(tabl,1,strpos(tabl,''.'')-1);
     tabl = substr(tabl,length(schem)+2);
   else
     schem = schem || ''%'';
   end if;
   select SRID into sr from geometry_columns where f_table_schema like
schem and f_table_name = tabl and f_geometry_column = $3;
  return sr;
END;
LANGUAGE 'plpgsql' WITH (iscachable,isstrict);
C.
--tThc/1wpZn/ma/RB--
