[Mapserver-users] Linux segmentation problem
Björn Platzen bplatzen at sosnetz.de
Tue May 13 08:39:14 EDT 2003
Hi Matt,
> I don't think mapserv is actually getting as far as reading the map
> file, because I get a segmentation fault whether I specify a valid
> map file or not. I'm pretty sure it's not that it can't find some
> shared libraries, as they normally complain that they are missing
> when you do "mapserv -v".
> Any more ideas?!
> Matt.
Maybe a shared library is not at the expected place??
Try 'ldd mapserv' and see, if all the shared liraries are found.
I don't know if that helps...
Bye,
Bjoern.
small office solutions
info at sosnetz.de  -  http://www.sosnetz.de
