[Mapserver-users] OracleSpatial switches to include...(correction)
Jesiel de Souza
jesiel at cttmar.univali.br
Tue May 13 09:27:49 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_008D_01C3193A.4DB968A0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Richard,
The variables that you attributed in the file "nmake.opt", at line 203, =
need to be used.
Include the variables as shown below, and compile it again.
After the compilation, verifies if ORACLESPATIAL support is activated.
( Execute mapserver.exe -v )
At line 459:
LIBS=3D$(MS_LIB) $(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) \
$(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
$(CURL_LIB) $(ECW_LIB) $(MING_LIB) $(PDF_LIB) \
$(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
$(XERCES_LIB) $(ORACLESPATIAL_LIB)
INCLUDES=3D$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
$(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
$(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
$(IMGGEN_INC) $(ERR_INC) $(ORACLESPATIAL_INC)
MS_CFLAGS=3D$(INCLUDES) $(REGEX_OPT) $(STRINGS) $(POSTGIS) \
$(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) \
$(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA) $(GDAL) \
-DFEATURE_INFO_HTML $(WFS) $(WFSCLIENT) $(PDF) $(EGIS) =
$(ORACLESPATIAL)
Regards,
Jesiel de Souza
----- Original Message -----=20
To: Jesiel de Souza=20
Sent: Tuesday, May 13, 2003 9:08 AM
Subject: RE: [Mapserver-users] OracleSpatial switches to =
Hi Jesiel,
=20
I am really sorry to bother you but I am at a loss. I have put the =
necessary information in the nmake.opt file (used by makefile.vc in =
version 3.7) and I recompiled.
=20
Yet, when I do the mapserv.exe -v ORACLESPATIAL is NOT listed as an =
INPUT..
=20
Am I doing something wrong?
=20
I have attached both my makefile.vc and my nmake.opt files to see if =
you can spot anything.
=20
There is one confusing thing to me. I am using PHP/MAPSCRIPT. Do I =
compile Mapserver first or PHP/MAPSCRIPT first?
=20
Again, MANY thanks for your help and time!
=20
Cheers,
=20
Richard
=20
=20
-----Original Message-----
From: Jesiel de Souza [mailto:jesiel at cttmar.univali.br]=20
Sent: Friday, May 09, 2003 3:41 PM
To: Becher, Richard
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] OracleSpatial switches to =
=20
Hi Richard,=20
To know if its compilation of the MapServer with OracleSpatial is =
correct, proceed the following way:=20
1. Execute mapserver.exe -v=20
2. The output must contain "INPUT=3DORACLESPATIAL"=20
Like this sample:
MapServer version 3.7 (development) OUTPUT=3DPNG SUPPORTS=3DTTF =
INPUT=3DTIFF INPUT=3DORACLESPATIAL INPUT=3DSHAPEFILE=20
In this case, the input says it does exists.
In other cases, you need to compile the MapServer again, including the =
OracleSpatial suports in your makefile.vc.
Regards,=20
Jesiel de Souza
=20
Sent: Tuesday, May 06, 2003 1:30 PM
=20
Thanks Jesiel.
=20
OK.I think I have properly compiled MapServer with the Oracle =
Spatial switch. It is a little different for me since I am using an =
nmake.opt file (the way it's set up with the latest version of =
MapServer).
=20
How can I tell if Oracle is properly referenced? I am using =
PHP_Mapscript.
=20
Also, I am not sure how to set up MapServer now that I have =
everything compiled. IIS is all set up and PHP and PHP_Mapscript are =
all working.
=20
But how do I create a new MapServer project?
=20
Many thanks in advance for your help and time!
=20
Cheers,
=20
Richard
=20
=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:v =3D=20
"urn:schemas-microsoft-com:vml" xmlns:o =3D=20
"urn:schemas-microsoft-com:office:office" xmlns:w =3D=20
"urn:schemas-microsoft-com:office:word" xmlns:st1 =3D=20
"urn:schemas-microsoft-com:office:smarttags"><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3DWord.Document name=3DProgId>
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<META content=3D"Microsoft Word 10" name=3DOriginator><LINK=20
href=3D"cid:filelist.xml at 01C31926.CEFCEE00" =
rel=3DFile-List><o:SmartTagType=20
name=3D"time"=20
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"></o:SmartTagT=
ype><o:SmartTagType=20
name=3D"date"=20
ype><!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<STYLE>st1\:* {
BEHAVIOR: url(#default#ieooui)
</STYLE>
<![endif]-->
<STYLE>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
p
{mso-margin-top-alt:auto;
margin-right:0in;
mso-margin-bottom-alt:auto;
margin-left:0in;
font-size:12.0pt;
span.EmailStyle19
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle20
font-family:Arial;
color:navy;}
span.EmailStyle21
font-family:Arial;
color:navy;}
span.EmailStyle22
font-family:Arial;
color:navy;}
span.EmailStyle23
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</STYLE>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]--></HEAD>
<BODY lang=3DEN-US style=3D"tab-interval: .5in" vLink=3Dpurple =
link=3Dblue=20
bgColor=3Dwhite>
<DIV><FONT face=3DArial size=3D2>Hi Richard,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>The variables that you attributed =
in the file=20
"nmake.opt", at <STRONG>line 203</STRONG>, need to be used.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Include the variables <FONT size=3D2>as =
shown below,=20
and compile it again.</FONT></FONT></DIV>
<DIV><FONT face=3DArial color=3D#808080 size=3D2></FONT><FONT =
face=3DArial=20
<DIV><FONT face=3DArial size=3D2>After the compilation, verifies if =
ORACLESPATIAL support is activated.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>( Execute mapserver.exe -v =
)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><STRONG>At line =
459:</STRONG></FONT></DIV>
<DIV><FONT face=3DArial size=3D1><FONT color=3D#808080>LIBS=3D$(MS_LIB) =
$(GD_LIB)=20
$(TIFF_LIB) $(JPEG_LIB) \<BR> $(PROJ_LIB) =
$(OGR_LIB)=20
$(GDAL_LIB)\<BR> $(CURL_LIB) $(ECW_LIB) =
$(MING_LIB)=20
$(PDF_LIB) \<BR> $(WINSOCK_LIB) $(POSTGIS_LIB)=20
$(IMGGEN_LIB) $(ERR_LIB) \<BR> =20
$(XERCES_LIB)</FONT> <FONT color=3D#0000ff> =20
$(ORACLESPATIAL_LIB)</FONT></FONT></DIV>
<DIV><FONT size=3D1></FONT> </DIV>
<DIV><FONT face=3DArial size=3D1><FONT =
color=3D#808080>INCLUDES=3D$(GD_INC) $(TIFF_INC)=20
$(JPEG_INC) \<BR> =
$(PROJ_INC)=20
$(REGEX_INC) $(GDAL_INC) $(OGR_INC)=20
\<BR> $(CURL_INC) =
$(MING_INC)=20
$(PDF_INC) $(POSTGIS_INC) \<BR> $(IMGGEN_INC)=20
$(ERR_INC)</FONT> <FONT color=3D#0000ff> =20
$(ORACLESPATIAL_INC)</FONT></FONT></DIV>
color=3D#808080>MS_CFLAGS=3D$(INCLUDES)=20
$(REGEX_OPT) $(STRINGS) $(POSTGIS)=20
\<BR> $(EPPL) =
$(PROJ)=20
$(TIFF) $(JPEG) $(GD) $(OGR) $(WMS)=20
\<BR> $(WMSCLIENT) =
$(MING)=20
$(IGNORE_MISSING_DATA) $(GDAL)=20
\<BR> =
-DFEATURE_INFO_HTML=20
$(WFS) $(WFSCLIENT) $(PDF) $(EGIS)</FONT> <FONT =
$(ORACLESPATIAL)</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Jesiel de Souza</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3DRichardBecher at SierraSystems.com=20
href=3D"mailto:RichardBecher at SierraSystems.com">Becher, Richard</A> =
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A =
title=3Djesiel at cttmar.univali.br=20
href=3D"mailto:jesiel at cttmar.univali.br">Jesiel de Souza</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Tuesday, May 13, 2003 =
9:08 AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> RE: [Mapserver-users]=20
OracleSpatial switches to include...(correction)</DIV>
<DIV><FONT face=3DArial size=3D2></FONT><BR></DIV>
<DIV class=3DSection1>
<P class=3DMsoNormal><FONT face=3DArial color=3Dnavy size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Hi=20
Jesiel,<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: =
Arial"><o:p> </o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">I am really =
sorry to=20
bother you but I am at a loss.<SPAN style=3D"mso-spacerun: yes"> =
</SPAN>I=20
have put the necessary information in the <SPAN =
class=3DSpellE>nmake.opt</SPAN>=20
file (used by <SPAN class=3DSpellE>makefile.vc</SPAN> in version 3.7) =
and I=20
recompiled.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Yet, when I =
do the=20
mapserv.exe =96v ORACLESPATIAL is NOT listed as an=20
INPUT=85.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Am I doing =
something=20
wrong?<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">I have =
attached both=20
my <SPAN class=3DSpellE>makefile.vc</SPAN> and my <SPAN=20
class=3DSpellE>nmake.opt</SPAN> files to see if you can spot=20
anything.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">There is =
one=20
confusing thing to me.<SPAN style=3D"mso-spacerun: yes"> =
</SPAN>I am using=20
PHP/MAPSCRIPT.<SPAN style=3D"mso-spacerun: yes"> </SPAN>Do I =
compile <SPAN=20
class=3DSpellE>Mapserver</SPAN> first or PHP/MAPSCRIPT=20
first?<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Again, MANY =
thanks=20
for your help and time!<o:p></o:p></SPAN></FONT></P>
Arial">Cheers,<o:p></o:p></SPAN></FONT></P>
Arial">Richard<o:p></o:p></SPAN></FONT></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DTahoma =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">-----Original=20
Message-----<BR><B><SPAN style=3D"FONT-WEIGHT: bold">From:</SPAN></B> =
Jesiel de=20
Souza [mailto:jesiel at cttmar.univali.br] <BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">Sent:</SPAN></B> </SPAN></FONT><st1:date =
Year=3D"2003"=20
Day=3D"9" Month=3D"5"><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">Friday, May 09,=20
2003</SPAN></FONT></st1:date><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma"> =
</SPAN></FONT><st1:time=20
Minute=3D"41" Hour=3D"15"><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">3:41=20
PM</SPAN></FONT></st1:time><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma"><BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">To:</SPAN></B> Becher, Richard<BR><B><SPAN =
style=3D"FONT-WEIGHT: bold">Cc:</SPAN></B>=20
mapserver-users at lists.gis.umn.edu<BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">Subject:</SPAN></B> Re: [Mapserver-users]=20
OracleSpatial switches to include...(correction)</SPAN></FONT></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3D"Times =
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: =
12pt"><o:p> </o:p></SPAN></FONT></P>
<DIV>
<P style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DArial color=3Dblack =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Hi =
Richard,=20
</SPAN></FONT><FONT color=3Dgray><SPAN=20
style=3D"COLOR: gray"><o:p></o:p></SPAN></FONT></P>
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">To know if =
its=20
compilation of the MapServer with OracleSpatial is correct, proceed =
the=20
following way: </SPAN></FONT><FONT color=3Dgray><SPAN=20
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">1. Execute =
mapserver.exe -v </SPAN></FONT><FONT color=3Dgray><SPAN=20
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">2. The =
output must=20
contain "INPUT=3DORACLESPATIAL" </SPAN></FONT><FONT color=3Dgray><SPAN =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Like this=20
sample:<BR>MapServer version 3.7 (development) OUTPUT=3DPNG =
SUPPORTS=3DTTF=20
INPUT=3DTIFF INPUT=3DORACLESPATIAL INPUT=3DSHAPEFILE =
</SPAN></FONT><FONT=20
color=3Dgray><SPAN style=3D"COLOR: gray"><o:p></o:p></SPAN></FONT></P>
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">In this =
case, the=20
input says it does exists.</SPAN></FONT><FONT color=3Dgray><SPAN=20
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">In other =
cases, you=20
need to compile the MapServer again, including the OracleSpatial =
suports in=20
your makefile.vc.</SPAN></FONT><FONT color=3Dgray><SPAN=20
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Regards,=20
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Jesiel de=20
Souza</SPAN></FONT><FONT color=3Dgray><SPAN=20
<P style=3D"MARGIN-LEFT: 0.5in"><FONT face=3D"Times New Roman" =
size=3D3><SPAN=20
style=3D"FONT-SIZE: 12pt"> <o:p></o:p></SPAN></FONT></P></DIV>
<BLOCKQUOTE=20
style=3D"BORDER-RIGHT: medium none; PADDING-RIGHT: 0in; BORDER-TOP: =
medium none; PADDING-LEFT: 4pt; PADDING-BOTTOM: 0in; MARGIN: 5pt 0in 5pt =
3.75pt; BORDER-LEFT: black 1.5pt solid; PADDING-TOP: 0in; BORDER-BOTTOM: =
medium none">
<DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DArial =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">----- Original Message =
-----=20
<DIV style=3D"font-color: black">
<P class=3DMsoNormal style=3D"BACKGROUND: #e4e4e4; MARGIN-LEFT: =
0.5in"><B><FONT=20
face=3DArial size=3D2><SPAN=20
style=3D"FONT-WEIGHT: bold; FONT-SIZE: 10pt; FONT-FAMILY: =
Arial">From:</SPAN></FONT></B><FONT=20
face=3DArial size=3D2><SPAN style=3D"FONT-SIZE: 10pt; FONT-FAMILY: =
Arial"> <A=20
href=3D"mailto:RichardBecher at SierraSystems.com">Becher, Richard</A>=20
<DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><B><FONT =
face=3DArial=20
size=3D2><SPAN=20
Arial">To:</SPAN></FONT></B><FONT=20
Arial"> <A=20
title=3Djesiel at cttmar.univali.br =
href=3D"mailto:jesiel at cttmar.univali.br">Jesiel=20
de Souza</A> <o:p></o:p></SPAN></FONT></P></DIV>
<DIV>
face=3DArial=20
size=3D2><SPAN=20
Arial">Sent:</SPAN></FONT></B><FONT=20
Arial">=20
</SPAN></FONT><st1:date Year=3D"2003" Day=3D"6" Month=3D"5"><FONT =
face=3DArial=20
Arial">Tuesday, May 06,=20
2003</SPAN></FONT></st1:date><FONT face=3DArial size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial"> =
Minute=3D"30" Hour=3D"13"><FONT face=3DArial size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">1:30=20
PM</SPAN></FONT></st1:time><FONT face=3DArial size=3D2><SPAN=20
Arial"><o:p></o:p></SPAN></FONT></P></DIV>
<DIV>
face=3DArial=20
size=3D2><SPAN=20
Arial">Subject:</SPAN></FONT></B><FONT=20
Arial"> RE:=20
[Mapserver-users] OracleSpatial switches to=20
include...(correction)<o:p></o:p></SPAN></FONT></P></DIV>
<DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT =
face=3D"Times New Roman"=20
size=3D3><SPAN=20
style=3D"FONT-SIZE: 12pt"><o:p> </o:p></SPAN></FONT></P></DIV>
color=3Dnavy=20
size=3D2><SPAN style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: =
Arial">Thanks=20
Jesiel.<o:p></o:p></SPAN></FONT></P>
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
Arial">OK=85I=20
think I have properly compiled MapServer with the Oracle Spatial=20
switch.<SPAN style=3D"mso-spacerun: yes"> </SPAN>It is a =
little=20
different for me since I am using an nmake.opt file (the way it=92s =
set up=20
with the latest version of MapServer).<o:p></o:p></SPAN></FONT></P>
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
Arial">How=20
can I tell if Oracle is properly referenced?<SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>I am using=20
PHP_Mapscript.<o:p></o:p></SPAN></FONT></P>
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
Arial">Also,=20
I am not sure how to set up MapServer now that I have everything=20
compiled.<SPAN style=3D"mso-spacerun: yes"> </SPAN>IIS is all =
set up and=20
PHP and PHP_Mapscript are all working.<o:p></o:p></SPAN></FONT></P>
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
Arial">But=20
how do I create a new MapServer =
project?<o:p></o:p></SPAN></FONT></P>
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
Arial">Many=20
thanks in advance for your help and =
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
size=3D2><SPAN=20
color=3Dnavy=20
size=3D2><SPAN=20
<DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 1in"><FONT face=3D"Times =
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: 12pt"> </SPAN></FONT><FONT =
face=3DArial=20
Arial"><o:p></o:p></SPAN></FONT></P></DIV></BLOCKQUOTE></DIV></BLOCKQUOTE=
></BODY></HTML>
------=_NextPart_000_008D_01C3193A.4DB968A0--
