[Mapserver-users] rojection library error. no system list, errno: 2
Benjamin Thelen
benjamin.thelen at ccgis.de
Wed May 14 08:16:13 EDT 2003
Thanks,
(ups, I forgot this mail in my drafts-folder)
see my posting to Frank Warmardam!
Ben
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
> Swaminathan, Gayathri
> Sent: Monday, May 05, 2003 7:34 PM
> To: 'Benjamin Thelen'; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] rojection library error. no system list,
> errno: 2
> Benjamin,
> See if this is useful
> http://lists.gis.umn.edu/pipermail/mapserver-users/2003-January/00
> 0540.html
> ~Gayathri
> From: Benjamin Thelen [mailto:benjamin.thelen at ccgis.de]
> Sent: Monday, May 05, 2003 10:21 AM
> To: mapserver-users at lists.gis.umn.edu
> errno: 2
> Hi everybody,
> I found something what Daniel Morrissette wrote some time ago:
> This happens if the file "epsg" is missing in the proj directory
> (/usr/local/share/proj/epsg on Unix), or if you try to use an epsg:XXXX
> code that doesn't exist in that file.
> But, both is not true in my case. The epsg-file IS there and the
> epsg:XXXX I
> specified are in the epsg-file.
> And here something that Frank Warmerdam wrote:
> errno = 2 is ENOENT which means file not found. Sorry for the awful error
> message, but basically I think the epsg file isn't found. Please ensure
> that
> the PROJ_LIB environment variable points to the directory with
> the EPSG file
> in it. On unix this is normally installed into /usr/local/share/proj,
> and it is in the nad directory within the proj distribution.
> I set the environment variable PROJ_LIB directly in a shell:
> "set PROJ_LIB=/usr/local/share/proj".
> But that didn't help as well.
> I thought it could be something with file permissions, but I don't think,
> proj4 is not allowed to access its own files. I have no more ideas at the
> moment. Anybody another idea?
> Sorry for my three mails. I was a bit to fast writing to the list.
> Thanks,
> Benjamin
> > [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Benjamin
> > Thelen
> > Sent: Monday, May 05, 2003 5:57 PM
> > Subject: [Mapserver-users] rojection library error. no system list,
> > errno: 2
> > Hi everybody,
> > after days of work, umn-mapserver is nearly running on my FreeBSD 4.7
> > System. I think I'll post what was neccessary to have
> > umn-mapserver running
> > on FreeBSD. Maybe that is something for a FAQ or even the manual.
> > But there are finally two problems. One is still the pdf-lib
> and the other
> > one is here:
> > http://servername/cgi-bin/mapserv?wmtver=1.0.0&map=/home/umn/test1
> > .map&reque
> > st=capabilities
> > responds the following:
> > - <HTML>
> > - <HEAD>
> > <TITLE>MapServer Message</TITLE>
> > </HEAD>
> > - <!-- MapServer version 3.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
> > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > <BODY BGCOLOR="#FFFFFF">msProcessProjection(): Projection
> library error.
> > no system list, errno: 2</BODY>
> > </HTML>
> > ./configure was successful, even with proj4. If needed I'll provide the
> > options and output as well as the output of make of course.
> > Anybody an idea? Where can this system list be found? What's its
> > name? Can I
> > somehow check the installation of proj4?
> > I have installed
> > FreeBSD 4.7
> > out of the ports-collection
> > apache 1.3.27
> > php 4.3.1
> > proj 4.4.5
> > gd-2.0.11
> > gdal-1.1.8
> > libWWW-5.4.0
> > directly from source code of course
> > mapserver 3.6.5
> > Thanks,
> > Benjamin
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
