AW: [Mapserver-users] Map file
woodbri at swoodbridge.com
Sat May 17 09:03:40 EDT 2003
Hi all,
I tried the http://wms.ccgis.de link but in IE6 I get errors like the
following on all of your links to maps.
ie: http://wms.ccgis.de/ccgis_client/dhtml/map.php?
Line: 1219, Char: 75, Error: Unterminated string constant
and no map displays. And if I mouse over the your tools bar or the
the legend text I get:
Line: 14, Char: 1, Error: Object doesn't support this property or
method, Code: 0
On 16 May 2003 at 14:12, Arnulf Christl (CCGIS) wrote:
> Hi,
> (here come the OGC disciples again...) If you use WMS (OGC Web Map
> Service) you can load several "layers" and overlay them in a client.
> Each map "layer" then represents one WMS. One WMS Server can contain
> several layers itself. An interesting feature here is that you can
> load different vendor's WMS together and overlay them in the same
> client.
> You can have a look at a demo on our server:
> Open the project "Germany", it is an UMN MapServer project hosted as
> WMS Open the project "BRD Administrativ", it is a SICAD/SD-IMS hosted
> as WMS Open the project "Overlay WMS" It contains both of the above
> projects together. You will see that the MapServer ist faster ;-) and
> will appear first in the client. A second or two later the other
> "layer" (or rather WMS Server) "BRD Administrativ" will be painted "on
> top" by the SICAD/SD-IMS WMS.
> To overlay the projects you have to load two Capabilities documents
> into your client. They are returned by your MapServer when it is WMS
> enabled (http://mapserver.gis.umn.edu/doc36/wms-server-howto.html) and
> you call an URL similar to this one here:
> http://wms.ccgis.de/umn/bin/mapserv.exe?map=germany.map&request=capabi
> lities&wmtver=1.0.0
> Regards, Arnulf.
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Marco
> Ferrari Gesendet: Freitag, 16. Mai 2003 12:27 An:
> mapserver-users at lists.gis.umn.edu Betreff: [Mapserver-users] Map file
> Hi,
> Is it possible to display more than map files in the same browser
> window? I am using a map file with many layers and so I thought to use
> more than map files. According to you, is correct? Thanks.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
