[Mapserver-users] Upload shapefile to create WMS service
Steve Young steve at sierraclubbc.org
Sun May 25 21:27:01 EDT 2003
Very nifty, worked on my first try.
Steve
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Gerald
Buckmaster
Sent: May 25, 2003 4:55 PM
To: Doug Cates; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Upload shapefile to create WMS service
I'm getting a 404...
Not Found (404)
 Original request: /ows/imfUnsupportedBrowser.jsp
 Not found request: /ows/imfUnsupportedBrowser.jsp
HTH
Gerald
On Sunday 25 May 2003 03:51 pm, Doug Cates wrote:
> Hi,
> I've developed a cool little tool for the internet mapping framework
(IMF).
> It allows a user to upload a shapefile and have it added to the map as a
> layer. You can try it out using the tool button that looks like a computer
> with an arrow above it on the "National Atlas of Canada - English" example
> site listed at:
> http://www.moximedia.com/imf_sites.html
> To try it, your shapefile set must be less than 4,000,000 bytes and be in
> one of the following projections. The shapefile display is automatically
> projected to the same projection as the map display, and in order for this
> to work you must be sure to select the proper source projection.
> - Geographic NAD27, NAD83, or WGS84
> - UTM zones 7N - 20N, NAD27, NAD83, or WGS84
> - Canada Lambert Conformal Conic, NAD83 or WGS84
> - BC Albers
> Behind the scenes, this uses MapServer. When the shapefile is uploaded, a
> MapServer .map file is created that contains just the one new layer, and
> the layer is added to the user's map session. Because IMF is
multi-service,
> the MapServer layer is displayed with the layers from other services.
> Comments, questions welcome.
> Doug
> Doug Cates
> Moxi Media Inc.
> 757 - 1641 Lonsdale Avenue,
> North Vancouver, BC, Canada V7M 2J5
> Phone:  604-984-8109
> Fax:    604-608-4764
> E-Mail: doug at moximedia.com
> Web:    www.moximedia.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
