[Mapserver-users] Problems with NQUERY and MapServer crash
James Perrins JamesPerrins at esdm.co.uk
Thu May 29 06:54:53 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_00A8_01C325D9.1E4CB3A0
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: 7bit
I have an application that is working fine using MODE=QUERY where the
user selects a point on the map and the nearest object is returned.
However when I try and change this so that a list of objects are
returned within a box I am having no success.
An example call is given below - this should definitely contain records
- I have seen other people having similar problems on the list group -
but I have not been able to find a reply.
http://localhost/scripts/mapserv.exe?map=c:\inetpub\wwwroot\mapserver\ES
DM.map&MODE=NQUERY&IMGSHAPE=12 60 156 60 156 204 12 204 12
60&mapext=171131.25 203531.25 180318.75 212718.75
Returns:
msQueryByShape(): Search returned no results. No matching record(s)
found.
I have tried the same with MAPSHAPE
If I add &LAYERS=SurveyEvents or &QLAYER=SurveyEvents to the above URL I
get a standard MS Crash dialog (I'm running on XP)
I have tested on both Mapserver 3.63 and the current development copy -
but with the same results each time.
My SurveyEvents layer is a MapInfo file - but this shouldn't make any
difference should it ?
Can I clarify should:
1)       IMGSHAPE should have pixel parameters?
2)       MAPSHAPE - as an alternative - have map co-ordinates ?
3)       Can anyone give me a working example call - and any other
pointers ?
4)       Am I doing something obviously wrong ?
Many Thanks
James
Content-Type: text/html;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html>
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0cm;
	margin-bottom:.0001pt;
	font-size:12.0pt;
	font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
p
	{margin-right:0cm;
	margin-left:0cm;
	font-size:12.0pt;
span.EmailStyle17
	{font-family:Arial;
	color:windowtext;}
@page Section1
	{size:595.3pt 841.9pt;
	margin:72.0pt 90.0pt 72.0pt 90.0pt;}
div.Section1
	{page:Section1;}
 /* List Definitions */
 ol
	{margin-bottom:0cm;}
ul
</style>
</head>
<body lang=3DEN-GB link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi,</span></font></p>
font-family:Arial'>&nbsp;</span></font></p>
font-family:Arial'>I have an application that is working fine using =
MODE=3DQUERY
where the user selects a point on the map and the nearest object is =
returned.</span></font></p>
font-family:Arial'>However when I try and change this so that a list of =
objects
are returned within a box I am having no success.</span></font></p>
font-family:Arial'>An example call is given below &#8211; this should =
definitely
contain records &#8211; I have seen other people having similar problems =
on the
list group &#8211; but I have not been able to find a =
reply.</span></font></p>
font-family:Arial'>http://localhost/scripts/mapserv.exe?map=3Dc:\inetpub\=
wwwroot\mapserver\</span></font><font
style=3D'font-size:10.0pt;font-family:Arial'>ESDM</span></font><font
style=3D'font-size:10.0pt;font-family:Arial'>.map&amp;MODE=3DNQUERY&amp;I=
MGSHAPE=3D12
60 156 60 156 204 12 204 12 60&amp;mapext=3D171131.25 203531.25 =
180318.75
212718.75</span></font></p>
font-family:Arial'>Returns:</span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'>msQueryByShape(): Search returned no results. No matching =
record(s)
found.</span></font></p>
style=3D'font-size:
12.0pt'>&nbsp;</span></font></p>
style=3D'font-size:
12.0pt'>I have tried the same with MAPSHAPE</span></font></p>
style=3D'font-size:
style=3D'font-size:
12.0pt'>If I add &amp;LAYERS=3DSurveyEvents or =
&amp;QLAYER=3DSurveyEvents to the above
URL I get a standard MS Crash dialog (I&#8217;m running on =
XP)</span></font></p>
style=3D'font-size:
style=3D'font-size:
12.0pt'>I have tested on both Mapserver 3.63 and the current development =
copy &#8211;
but with the same results each time.</span></font></p>
style=3D'font-size:
12.0pt'>My SurveyEvents layer is a MapInfo file &#8211; but this =
shouldn&#8217;t
make any difference should it ?</span></font></p>
font-family:Arial'>Can I clarify should:</span></font></p>
<p class=3DMsoNormal =
style=3D'margin-left:36.0pt;text-indent:-18.0pt'><font size=3D2
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>1)<font =
size=3D1
face=3D"Times New Roman"><span style=3D'font:7.0pt "Times New =
Roman"'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
</span></font></span></font><font size=3D2 face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial'>IMGSHAPE should have pixel =
parameters?</span></font></p>
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>2)<font =
size=3D1
style=3D'font-size:
10.0pt;font-family:Arial'>MAPSHAPE &#8211; as an alternative &#8211; =
have map
co-ordinates ?</span></font></p>
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>3)<font =
size=3D1
style=3D'font-size:
10.0pt;font-family:Arial'>Can anyone give me a working example call =
&#8211; and
any other pointers ?</span></font></p>
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>4)<font =
size=3D1
style=3D'font-size:
10.0pt;font-family:Arial'>Am I doing something obviously wrong =
?</span></font></p>
font-family:Arial'>Many Thanks</span></font></p>
font-family:Arial'>James</span></font></p>
<p><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:12.0pt'>&nbsp;</span></font></p>
</div>
</body>
</html>
------=_NextPart_000_00A8_01C325D9.1E4CB3A0--
