[Mapserver-users] Problem using FILTER.
Eduardo Spremolla
edspremolla at Antel.com.uy
Thu May 29 09:24:14 EDT 2003
Try FILTER "[masa]='001'"
Eduardo Spremolla
Montevideo, Uruguay
El jue, 29 de 05 de 2003 a las 09:20, braulioen at ono.com escribió:
> Hi:
> I am trying to filter a layer shape and I cannot. The file map is the
> following one:
> LAYER
> NAME poligonos
> DATA poligonos
> STATUS DEFAULT
> TYPE POLYGON
> FILTER "masa='001'"
> CLASS
> COLOR 212 212 212
> OUTLINECOLOR 0 0 0
> TEMPLATE poligonos_template.html
> END
> END
> where "masa" is the filtered feature of the shapefile, and I obtain
> all the results, as if I did not use FILTER. Which is my error?.
> Thanks.
> Braulio.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
