[Mapserver-users] styleObj? member of classObj?
Daniel Morissette
morissette at dmsolutions.ca
Sat May 31 17:50:17 EDT 2003
Gerald,
You have to call $class->GetStyle( style_index ) to access a given
style. And you use ms_newStlyeObj($class) to create a new style inside
a class.
<long_story>
Since there can be more than one style in a class, we cannot present a
single class member called style like we do for style->label for
instance. We would have to present an array of styles, not just a
single style... I guess we could have tried to do it this way, but there
may have been some issues with the PHP wrappers and anyway the
getStyle() approach was more consistent with the way layers are accessed
inside the map, and the way classes are accessed inside layers.
</long_story>
Daniel
Gerald Buckmaster wrote:
> Greetings,
> Trying to understand the 3.7/4.0 documentation in regards to styleObjs.
> Reading the info on styleObj class leads me to believe instances of styleObj
> are always embedded inside the classObj, yet when I look at the members of
> the classObj, I don't see it named:
> Members:
> string name
> string title
> int type
> int status (MS_ON, MS_OFF or MS_DELETE)
> int minscale
> int maxscale
> string template
> labelObj label
> int numstyles
> All I see is a member called numstyles and a method called getStyle().
> So how do I "attach" a styleObj to a classObj? Doesn't seem to be consistent,
> ie the labelObj is named label.
> $cityLabel = $cityCls->label; # I understand
> $cityStyle = $cityCls->???; # no clue
> Thanks,
> Gerald
