[Mapserver-users] compiling regex on windows
Abram Gillespie
agillesp at vt.edu
Mon Nov 3 00:00:09 EST 2003
i'm trying to compile the regex lib on windows 2000 with vs.net. i get
the following error:
c:\source_code\regex-0.12\regex.c(63) : fatal error C1083: Cannot open
include file: 'strings.h': No such file or directory
then when i define HAVE_STRING_H to try to fix the above error i get
these:
c:\source_code\regex-0.12\regex.c(808) : error C2365: 're_set_syntax' :
redefinition; previous definition was a 'function'
c:\source_code\regex-0.12\regex.h(404) : see declaration of
're_set_syntax'
c:\source_code\regex-0.12\regex.c(808) : error C2146: syntax error :
missing ';' before identifier 'reg_syntax_t'
c:\source_code\regex-0.12\regex.c(808) : fatal error C1004: unexpected
end of file found
anything i can do?
thanks.
abe
