[Mapserver-users] Migration from 3.5 to 4.0
    Vinko Vrsalovic
    vinko at cprsig.cl
    Wed Nov  5 17:50:04 PST 2003
Hello,
	I found in some old backups a really nice app that was made in
	good old 3.5 times. Back then it worked perfectly. In it i embedded
	the scalebar in the map, with transparent set to ON, but now (with 4.0)
	it the bakcground is not rendered transparent, so it's blocking a
	part of the map. As i'm using 4.0 I tried to define the
	following outputformat:
  OUTPUTFORMAT
      NAME png
      MIMETYPE image/png
      DRIVER GD/PNG
      EXTENSION png
      IMAGEMODE RGBA
      TRANSPARENT TRUE
  END
	But when using it, i get
	gd-png:  fatal libpng error: Invalid number of colors in palette
	gd-png error: setjmp returns error condition
	I also get the same error when using IMAGEMODE RGB and TRANSPARENT FALSE
so i guess it has to do with the number of bits instead of the
transparent setting. It works if i set IMAGEMODE to PC256.
	I checked the list, and the problem is mentioned, but didn't
get why it might happen.
	So three questions here, what can I be doing for it to fail that way?
I was using a reference map with a 8bit png image, so I changed it to 24 bits,
but the problem remains.
	The second is, if I get the outputformat with RGBA to work,
will the scalebar with transparent set to true work?
	And the third is, is there a way to embed the scalebar with
transparent background with PC256 mode?
Thanks,
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
More information about the MapServer-users
