[Mapserver-users] installation
Scott Ferguson
scottf at secr.com
Thu Oct 2 14:44:46 EDT 2003
thanks
i've got mapserver running now.
I'm testing the 'demo' map file now. Looks like the demo file uses gif
images. I'll probably get an error message since I don't have the gif
licensing.
Scott
-----Original Message-----
Sent: Thursday, October 02, 2003 11:27 AM
To: scottf at secr.com
Cc: Mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] installation
Hi
Have you checked in /usr/local/lib if your compiled GD
yourself it would be in there, but if you are using a rpm
it is in /usr/lib
you may need to add the path to /usr/local/lib in your
ld.so.conf and run ldconfig
Cheers
Randy
--- Scott Ferguson <scottf at secr.com> wrote:
> after compiling the source code and creating the
> 'mapserv' file I received
> this message when typing the ./mapserv command at the
> prompt to test it:
> "./mapserv: error while loading shared libraries:
> libgd.so.2: cannot open
> shared object file: No such file or directory"
> I've already compiled these librabries GD, Proj, and
> Freetype with success.
> Although, the 'libgd.so.2' file was not in my GD
> directory.
> any ideas as to the problem??
> thanks
> Scott Ferguson
> GIS Manager
> Global Routing Technologies
> 636.449.3212
> scottf at secr.com
> www.grti.net
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
