[Mapserver-users] MapServer 3.5: Error Message
Eric Bridger
eric at gomoos.org
Thu Oct 2 13:34:01 EDT 2003
At 11:31 AM 10/02/2003 -0400, McNeil, Todd W. (TMCNEIL) wrote:
>Hi All,
>I also downloaded the Tutorial and have come across an error message that
>does not make sense to me. I am going through the 1st example of section 1
>of the tutorial. I use this URL to retrieve a map image:
>http://tmcneil1/Scripts/mapserv.exe?map=e:/projects/tutorial35/s1/s1ex1.map&
>amp;mode=map
><http://tmcneil1/Scripts/mapserv.exe?map=e:/projects/tutorial35/s1/s1ex1.map
>&mode=map> , and the resulting error message is:
>mapserv(): Web application error. No template provided.
You will most likely need to edit the html files you downloaded in the Tutorial. You may also
need to edit the s1ex1.map file to change any paths to paths suiting your setup.
