[Mapserver-users] Re: Building GDAL with Xerces on Redhat 9
Doug Cates
doug at moximedia.com
Thu Oct 2 21:12:24 EDT 2003
Thanks to assistance from Armin Burger, I've successfully got the WFS
SERVER going on RH9 using xerces 1.7.0 and gdal 1.1.9, configuring gdal
with the following options:
--with-xerces --with-xerces-lib="-L/usr/local/lib -lxerces-c1_7_0
-lpthread"
Great user support around here. Thanks.
Doug
On Thu, 2003-10-02 at 12:55, Doug Cates wrote:
> Hi,
> I'm trying to build a development version of MapServer 4.1 with WFS
> SERVER support so I can test using complex filters. I'd use a Windows
> binary if one was available, but since it isn't, I'm trying to put it on
> a RH9 box here, the only Linux box that I have available.
> I can't seem to get GDAL to build with Xerces-C. I noticed a thread
> earlier this year about this that seemed to indicate that GDAL 1.1.8
> must be used with Xerces-C 1.6.0. Is that the only valid combination
> allowed, or has GDAL been updated to support newer versions of Xerces?
> An idea: The installation docs should have a version matrix, specifying
> the exact versions of all the supporting libraries that should be used
> when building a specific version of MapServer.
> Does anyone have any tips on installing this? Would anytone be willing
> to look at my installation logs to see if anything jumps out at them?
> Regards,
> Doug
