[Mapserver-users] mapserv SDE 8.3 interface
Pryor, Clayton J
CJPRYOR at sandia.gov
Mon Oct 6 12:16:18 EDT 2003
I am putting together a mapserver prototype for a current application that I
implemented in ArcIMS. I have searched the web and the MapServer email list
archives for help with this problem to no avail.
I am trying to get mapserver up and running with an ArcSDE interface. I
have been able to compile mapserver with SDE libraries but when I try to run
mapserv from the command line or the web server I get the following message:
./mapserv: error while loading shared libraries: libsde83.so: cannot open
shared object file: No such file or directory.
When I execute ldd ./mapserv I get the following ArcSDE library related
libsde83.so => not found
libpe83.so => not found
libssg83.so => not found
I am running all of this on Linux RedHat 9 on an IBM Thinkpad model A31.
FYI, here are my configuration options for mapserv:
./configure --with-sde=/usr/local/arcsde/sdeexe83 --with-sde-version=83
--with-sde=/usr/local --with-gd=/usr/local --with-php=/usr/local/php-4.3.3
--with-proj=/usr/local
One thing I have not done is set up an ArcSDE connection to the database on
the prototype machine. I will be looking into that next. Could that be the
problem?
I am posting this message now in case I am missing something other than an
ArcSDE connection to the database.
Any help is appreciated.
Sincerely,
Clay
Clayton J. Pryor phone (505) 845-3557
Sandia National Laboratories
Critical Infrastructure Surety fax (505) 844-9641
PO Box 5800 MS 0451
Albuquerque NM 87185-0451 email cjpryor at sandia.gov
