[Mapserver-users] reference map in 4.0
Steve Lime steve.lime at dnr.state.mn.us
Mon Oct 6 18:21:41 EDT 2003
There are no seperate controls for the box versus the marker. You have
to have filled for both or outlines for both. Sorry.
Steve
BTW Please fill out a bug report for this one. Ideally you'd want
seperate styles for each, in fact that's probably the best solution. Add
a BOXSTYLE and a MARKERSTYLE...
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Richard Greenwood <Rich at GreenwoodMap.com> 10/4/2003 11:18:39 AM
I am using the same reference map definition in 3.6 and 4.0 (see below)
In
3.6 the box is not filled, it is just an outline. In 4.0 the box is
filled.
I want just an outline like I had in 3.6, so I set the color to -1 -1
-1.  This does the trick for the box, but then I get no marker when I'm
zoomed in below the MINBOXSIZE threshold. Am I missing something, is
this a
catch 22?
Rich
REFERENCE
         IMAGE "/inetpub/wwwroot/mapserver/graphics/jh_ref_map.gif"
         EXTENT 2365000 1320000 2555000 1600000
         SIZE 153 226
         STATUS OFF              # gets turned on by URL
         OUTLINECOLOR 255 0 0
         COLOR 255 0 0
         MARKER star
         MARKERSIZE 20
         MAXBOXSIZE 150
         MINBOXSIZE 25
END
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
